Author Topic: helix 9 si gps  (Read 8976 times)
Offline Cutaway70
  • Unit(s): Helix9 si gps
helix 9 si gps
« on: June 27, 2016, 10:03:46 AM »
Thanks for the add.  Recently purchased this spring.  I have moved transducer 4 times and still same problem.  I get false bottom reading.  i am in 8ft water and digital display says 19ft when in 2d i have 2 readings one at correct depth and one at 19ft. Think i tried everything but nothing seems to work.  Any suggestions would be appreciated. I am running the teansducer that came with unit should i upgrade to the hdsi.
Re: helix 9 si gps
« Reply #1 on: June 27, 2016, 12:16:20 PM »
Have you tried to go to switchfire clear and reduce the sensitivity?  If you are going to mostly in shallow water, sometimes setting the max depth to a number a little more than your actual depth will help also.....just remember it has been changed when you get into deeper water.
You probably have a hard bottom area.
« Last Edit: June 27, 2016, 12:18:30 PM by Bob B »
Offline Franerp87
  • Unit(s): Helix 9 SI & 360 Imaging
  • Software: original
  • Accessories: 360 Imaging
Re: helix 9 si gps
« Reply #2 on: January 24, 2017, 08:41:17 PM »
Hello everyone & Thanks for add.
I have had the same problem in my unit (helix 9 SI ) Humminbird Spain has changed the unit & transducer for a new other and I still have to go water to test it.
I had wrongs reads in a DELTA RIVER this bottom its very soft...
Regards
Last post January 15, 2016, 09:35:29 PM
Last post January 31, 2016, 10:16:00 PM
Last post August 27, 2016, 05:28:39 PM
by mako9man2
Last post April 16, 2016, 09:26:41 PM
Last post May 24, 2016, 03:25:55 PM
by jepik
Last post August 29, 2016, 10:15:47 PM
