Author Topic: Second faulty 898 SI transducer  (Read 6943 times)
Offline scylla
  • Unit(s): 535
« on: April 10, 2016, 06:38:18 AM »
Not very happy today.  For the second time my 898 SI combo has a problem with the transducer.  First one replaced under warranty within the first twelve months.  This one is coming up two years and the head unit will not detect the transducer.  Another Humminbird unit I tested it on says the same.  It went from good to will not read.  No cable issues apparent and transducer is in good condition.
It seems to me they are consumables - but not at the price.  I have two boats and between them three other sounders.  Never have any problems with other transducers - now two SI transducers in three years.  Not happy!!!!
I will be contacting Hummingbird through the retailer.  I can tell you it if I do not get a satisfactory result I will be posting  on every forum in Australia that I can find.
Anyone else having similar issues?
Cheers
Scylla
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Second faulty 898 SI transducer
« Reply #1 on: April 10, 2016, 08:26:17 PM »
No
« Reply #2 on: April 10, 2016, 09:47:22 PM »
Is the xducer showing "Not Connected" in the Accessories test view ... ??
Or ... are all the Sonar views showing no data ... ??
Offline scylla
  • Unit(s): 535
« Reply #3 on: April 11, 2016, 04:43:54 AM »
Hello Rickie
It is showing not connected (on the 898 and as well when i use it on an older matrix)
The older matrix transducer shows as connect on both units
Cheers
« Reply #4 on: April 11, 2016, 10:24:04 PM »
There's not much else to check except to inspect the pins carefully to make sure they're all there ...
Offline scylla
  • Unit(s): 535
« Reply #5 on: April 13, 2016, 08:42:46 AM »
Thanks Rickie
All pins present and male and female ends look clean and gold.
Very disappointing to have two faulty transducers in 3 years.
by Sonshine Fishing
Last post April 02, 2010, 02:04:34 PM
Last post May 08, 2012, 02:21:30 AM
by ColeM
by Brian37075
by jgcox6
by bobcoy
Last post June 03, 2014, 11:52:29 AM
by snowman48047
