Author Topic: How do you get the water temperature on the screen  (Read 12163 times)
Offline Birdhunterden
  • Unit(s): 898c si
  • Software: ?
« on: February 29, 2016, 10:43:02 PM »
I cut the transducer cable and replaced it with a new one   The same kind it worked before but not now it's a 898cSI. I change to a 899 c SI and the temperature came on I put the 898 on another boat and still not working
Re: How do you get the water temperature on the screen
« Reply #1 on: March 02, 2016, 02:03:22 AM »
*Press Menu twice to get into the Main Menu System ...
*Cursor over to the Setup tab ...
*Cursor down to "Select Readouts" ...
*Set one of the data boxes to Temperature ...
The Temperature choice is only available in Normal Operation mode (not in Simulator) ...
  • Unit(s): 898c si
  • Software: ?
« Reply #2 on: March 02, 2016, 10:51:26 AM »
Rickie thanks  I try it still not working I try it on another boat still doesn't work I called humminbird and they told me to try to upgrade right now I have 6.640  so I see what the next upgrade will be. Thanks again
« Reply #3 on: March 02, 2016, 10:29:20 PM »
Let us know what transpires so we can know what to troubleshoot next ...
  • Unit(s): 898c si
  • Software: ?
« Reply #4 on: March 02, 2016, 11:17:32 PM »
Will let you know when I upgrade I hope it works because humminbird was $340.45 to fix it
Last post August 30, 2010, 02:55:22 AM
Last post March 19, 2012, 12:34:33 PM
Last post June 28, 2012, 08:19:30 AM
by oz
Last post December 20, 2012, 02:39:09 PM
Last post May 28, 2013, 11:54:55 AM
Last post March 17, 2014, 10:55:29 AM
Last post April 15, 2014, 10:39:12 AM
Last post June 03, 2014, 11:52:29 AM
by snowman48047
