Author Topic: Map Card for HB Helix 7 SI/GPS ?  (Read 11040 times)
Offline jleis
  • Unit(s): Helix 7 SI
« on: December 08, 2015, 05:23:41 PM »
I am about to purchase the Humminbird Helix 7 SI / GPS . I will be using the unit primarily in SouthWest Florida coastal waters (not lakes). Is the Navionics+ map compatible with the Humminbird Helix 7 SI?   Humminbird customer support says YES it is but on the Navionics website, Navionics+, HotMaps Premium and even Navionics Gold show as incompatible when you select  compatibility with Helix 7 SI/GPS. So...
I'm trying to figure out:
1) what is the best compatible map card for me in coastal waters? and
2) where to buy it?
Thanks in advance for any guidance / clarification.
Shows as compatible and matches what Humminbird Cust Support said:
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Map Card for HB Helix 7 SI/GPS ?
« Reply #1 on: December 09, 2015, 10:50:34 AM »
Humminbird site says Navionics plus is not supported. Bob
PS. The Helix 9 and 10 support it. I would call HB to be sure. Navionics put that special line in there for some reason.
« Last Edit: December 09, 2015, 10:56:33 AM by bobcoy »
Offline jleis
« Reply #2 on: January 05, 2016, 07:45:47 PM »
Ok, thank you BobCoy.  I have an update and new question.  Update - Navionics has updated their website and the Navionics + is compatible with the Helix 7 SI.  I have purchased both and they work fine together so far (1 month).
Question: How do I turn on the "Sonar Maps" in the Helix 7 unit.  I can't find in the manual or google how to do that?
Offline bobcoy
« Reply #3 on: January 05, 2016, 08:42:42 PM »
I an digging for the info. You need to set your chart as fish n chip somewhere. I will keep looking.
The FishN'Chip setting is the Chart Select in the Chart tab. You scroll over to the setting that shows the slot the card is in and it will show FishN'Chip Card.
My card is in the left slot so my selection is named "Left FishN'Chip Card".
That is where the Sonar Charts layer will be viewed.( stolen from Wayne P post)
That is if you downloaded the sonar chart portion(separate download from the regular map)
« Last Edit: January 05, 2016, 08:53:33 PM by bobcoy »
Last post April 03, 2015, 06:03:07 PM
by Tigersix
Last post June 04, 2015, 11:12:54 AM
Last post January 01, 2016, 04:23:22 PM
by dcappotto
Last post January 31, 2016, 05:32:33 PM
Last post March 11, 2016, 02:31:40 PM
by bigonsmallies
Last post March 18, 2016, 12:13:07 PM
by rbdavis3591
Last post March 27, 2016, 10:53:15 AM
by victor_humminbird
Last post May 08, 2016, 11:23:36 AM
by rdcress
