Author Topic: Question for Humminbird PC/Google Map/GPX users  (Read 7194 times)
Offline thinkinfish
  • Unit(s): workinonit
« on: August 21, 2015, 01:42:28 PM »
I've been playing with my 899 & related software waiting for my upgrade xducer to arrive.  HPC is cool!  Since I have no actual 899 data to experiment with I substituted a GPX file I created with Streets and Trips awhile ago.  Problem is, when using those coordinates in Google Map, many waypoints are off by 50-300 ft. (including launch ramp locations built with S&T).
Question.  Is there an easy way, using Google Maps, to reposition (using cursor to slide?) a waypoint that is not accurate and have Google update its coordinates so the map displays correctly?  Then I'd create a new gpx file with correct coordinates to use with Google/Hum PC.
In the past I never used Google Maps since Microsoft's S&T did everything I needed and was simple to use as a trip planning tool.  However S&T is now discontinued with nothing to replace it from MS.  The errors I see are probably attributed to the use of different map software and some by me marking locations from my recliner.
Offline thinkinfish
Re: Question for Humminbird PC/Google Map/GPX users
« Reply #1 on: August 22, 2015, 10:55:26 AM »
Forget it...I erroneously used a very early test GPX file from a map I had simply estimated where to put waypoints on a map graphic.  :P
Admin you can delete this post.
« Reply #2 on: August 22, 2015, 10:53:17 PM »
Whew ...I'm glad you figured that out ...
I was about to go find Camohunter or LittleGazzoo ...(I sure didn't know the answer) ...
Last post April 07, 2010, 02:48:47 PM
by Drifter
Last post October 25, 2011, 04:38:45 PM
Last post January 22, 2012, 09:18:22 PM
by Fish Pirate
Last post December 06, 2017, 05:20:28 PM
by sylvanboat
Last post April 15, 2014, 07:47:35 PM
by Teej
Last post June 08, 2015, 02:09:34 PM
by Bubba Canuck
Last post August 11, 2015, 10:20:24 AM
by lancepeterson
Last post April 24, 2017, 04:03:53 AM
by allanrbaker
