Author Topic: mapping outside of parameters  (Read 6493 times)
Offline d.sonnenburg
  • Unit(s): 898C SI, 998c HD SI
« on: July 28, 2015, 02:52:13 PM »
I recently mapped a lake and uploaded the data to the computer. I created an outline of the lake as a kml. file in google earth. now when it makes a map it goes beyond my outline and maps land area thus wrecking my map. all of my sonar recording are within the outline that i made so i have no idea why it is showing data outside of this area. Any help would be much appreciated. Thanks!
Offline D S
  • Software: 7.5
Re: mapping outside of parameters
« Reply #1 on: July 30, 2015, 12:48:28 AM »
d go to
tools..setting...general ..
look at shorelines
and make sure you have selected your shorelines  and that it isn't using the default shoreline as it is often off by quite a bit
for your own impoerted kml file
try
use shorelines
user defined data
see if that helps
ds
stgr
« Reply #2 on: July 30, 2015, 02:31:16 PM »
I already had it set up that way. but thanks!
Offline CamoHunter
« Reply #3 on: July 31, 2015, 12:44:50 PM »
After you imported the Google Earth .kml file, did you remember to open the autochart file for your shoreline, and change the data type to shoreline?
pages 28-36 here:
https://drive.google.com/file/d/0B2IE_4njdjrPMU5NcV9QQkY4cG8/view?usp=sharing
Last post December 20, 2010, 06:26:40 PM
by Rickard
Last post January 22, 2013, 04:21:30 AM
by Rüdiger
Last post June 04, 2013, 09:37:21 PM
by matt 01
Last post June 18, 2013, 12:44:31 PM
Last post June 18, 2013, 02:15:13 PM
Last post August 05, 2013, 05:18:35 PM
by Austin358
Last post May 22, 2015, 02:03:10 PM
by Vinniez520
Last post April 06, 2016, 07:53:14 PM
by bobcoy
