Author Topic: 1197 losing gps after 7-10 min  (Read 7241 times)
Offline KevMc
  • Unit(s): 2 x solix 12, 1197
« on: June 22, 2015, 10:33:22 PM »
My 1197 is losing the gps after 7-10 min.......
software 6.640
gps = AS GRP (new module, old was doing the same)
restart, and it will work fine for 7-10 min, then "gps not connected"....
reinstalled the software, reset defaults, tried it with map cards removed........
works every time it's restarted.....for 7-10 min!!!
Same on the trailer, not moving, not moving cables, not pushing any buttons.......
$500 flat repair fee....... :'( :'( :'(
Re: 1197 losing gps after 7-10 min
« Reply #1 on: June 22, 2015, 11:37:34 PM »
I would 1st try wiggling the cable while viewing the Connected Accessory view (you will have to make this view Visible under the views tab) ...
I would then try bending the pins slightly to try to get better contact ...
I would then try finding someone with a HB GPS antenna to cross test ...
Offline KevMc
« Reply #2 on: June 23, 2015, 09:40:37 PM »
wiggling cables has no effect.......
bend pins.....??........works fine on trailer,..no movement,..... for 7-10 mins then quits.
This is the 2nd gps module (this one new), both same prob.
« Reply #3 on: June 23, 2015, 10:29:38 PM »
What software version do you have on the 1197?
Last post September 09, 2009, 08:59:50 PM
Last post March 23, 2010, 09:21:30 AM
Last post April 26, 2012, 12:28:08 PM
Last post June 13, 2012, 10:16:17 AM
Last post August 16, 2012, 02:56:00 PM
Last post May 16, 2013, 05:09:56 PM
by EZM
Last post May 09, 2015, 10:09:46 PM
Last post May 23, 2022, 08:04:36 AM
by Thermite
