Author Topic: 998 hd down imaging interference.  (Read 6226 times)
Offline kerryd15
  • Unit(s): 798C SI
« on: June 16, 2015, 11:13:54 PM »
i was out with a friend that has a 998 hd the side image works fine and the 2d works fine. The DI is all white lines across the screen. It didn't do this when we first went out. We basically shut everything off in the boat including trolling motor, the 958, live well. Nothing made it better. After they went home, they started it in demo mode and it still showed the lines. I will get a picture up when I can. When I changed screen views it would be clear, then the white would start scrolling across. Thanks for any help.
« Last Edit: June 16, 2015, 11:53:19 PM by kerryd15 »
Offline FishSeeker
  • Unit(s): Gen 1 Helix 12 Si & 10 SI
  • Software: 1.9
  • Accessories: Ulterra 80
Re: 998 hd down imaging interference.
« Reply #1 on: June 17, 2015, 01:51:26 AM »
I'm no expert, but it may be a software bug related to the DI Sensitivity settings.
Try turning the DI Enhanced Sensitivity to "Off"
Re this article;  http://forums.sideimagingsoft.com/index.php?topic=8227.0
Hope it works for you!
Offline FishSeeker
  • Software: 1.9
« Reply #2 on: June 17, 2015, 01:53:40 AM »
Correction - I was referring to the "Sharpness" setting in the "DI Enhanced" menu.
« Reply #3 on: June 17, 2015, 09:24:41 PM »
I have read that increasing the Chart Speed above 3 also works to get rid of the gremlin lines with the DI Sharpness set to On ...
Last post January 12, 2010, 07:43:29 PM
by garyr
Last post March 14, 2013, 04:37:52 PM
by Rickard
Last post November 17, 2013, 08:50:09 PM
Last post April 07, 2014, 03:01:09 PM
Last post March 17, 2017, 07:47:49 PM
by Boots
