Author Topic: Left side of si "fuzzy"  (Read 12150 times)
Offline steelebob
  • 1994 TRACKER NITRO 160 and 4 cyl 2017 Yamaha 70 h
  • Unit(s): Helix 2nd gen 10 and 9
  • Accessories: Ulterra
« on: May 30, 2015, 04:17:15 PM »
This been going on for a few weeks. The screen starts getting fuzzy at 5mph on the left side, then if I switch the engine to idle the left side gets streaky black blogs as pict. This will happen no matter what lake I'm on. I repositioned transduce and have tilted it many different ways.
I dream of things that never were, and ask why not?
Offline steelebob
Re: Left side of si "fuzzy"
« Reply #1 on: May 30, 2015, 04:19:00 PM »
Sorry first time posting pictures. This is my trans setup.
Offline steelebob
« Reply #2 on: May 30, 2015, 04:20:23 PM »
This is a different angle
Offline N9Phil
« Reply #3 on: May 30, 2015, 06:36:19 PM »
Raise your motor up a bit and that might help.  The top 3 feet or so on the left side image is your motor blocking your signal.
Offline steelebob
« Reply #4 on: May 30, 2015, 07:11:44 PM »
The picture was taken in the driveway, so the motor is not in its "normal" position. How do you raise a motor??
Offline RonnieB
  • RonnieB
  • Software: 2.0
« Reply #5 on: May 30, 2015, 11:01:05 PM »
Trim or Tilt your motor up. Mine does the same thing. I have to trim my motor more than I thought. Mine did real good in a local clear lake with just 2 people in boat. Last trip with 4 people in boat full of gear, ice, full baitwell, ice etc. I actually had alot of difficulty fine tuning my setup. I wonder if weight and the depth that the boat sits in water affects it.  Even at 6-7 mph, the angle of my boat in the water is slightly different with motor trimmed up. Maybe boat is spraying water or bubbles toward transducer?? I'm still learning...  :P
What was your chart speed, sensitivity and sharpness set at?
« Reply #6 on: May 30, 2015, 11:28:19 PM »
Something looks more amiss than just the left side ...
Next time out get screenshots with these ...:
*Bring SI Range in to about 50ft each side ...
*Boat speed and chart speed at about 3 ...
*SI Frequency (try both 455kHz and 800kHz) ...
*Beam Frequency 200kHz ...
*Max Depth under Sonar tab to 20ft below deepest water in your lake ...
*Contrast 10-12 ...
*Sharpness Off  ...
*Noise filter under Sonar tab Off ...
« Last Edit: May 30, 2015, 11:29:43 PM by rnvinc »
Offline steelebob
« Reply #7 on: May 31, 2015, 06:15:41 AM »
I'll park it on a hill so the motor is in the "normal" position and take another picture. I  automaticly run the motor in ?"max trim" now, so I will try playing with that.
by RuffWood
Last post October 02, 2012, 11:00:38 AM
Last post July 24, 2013, 12:54:05 AM
by LittleGazoo
Last post January 09, 2014, 08:07:12 AM
by Gattlin
Last post July 22, 2014, 02:16:32 AM
Last post June 05, 2016, 01:02:49 PM
by fishreed
