Author Topic: NEMA output  (Read 12070 times)
Offline ETnSC
  • Unit(s): 1197c SI
  • Software: 5.43
NEMA output
« on: March 07, 2010, 11:36:54 AM »
I have an 1197c SI on the way.  I need one NEMA output for Smartcraft guagess and one in/out for DSC on a VHF radio.  Is this possible on an 1197?  If so what cables do I need to make the connections?  I read in another post that someone was able to get AIS to display.  With a NEMA in/out connection will the 1197 display position info recieved from the DSC on an incoming call?
ET
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
Re: NEMA output
« Reply #1 on: March 07, 2010, 01:15:09 PM »
Hi ETnSC and welcome to the forum,
Hendrik had his 1197 connected to AIS. He can give you advice on this.
If you want to get NMEA data send out check here for a cable solution:
http://forums.sideimagingsoft.com/index.php?topic=711.0
And here's a "how to" from Humminbird's website to rigg up the Bird to Smart Craft gauges:
http://store.humminbird.cust.shopatron.com/media/document/NMEAoutputtoGPSSpeedometerScenarios.pdf
Hope this helps
Harry
« Last Edit: March 07, 2010, 01:28:03 PM by Jolly Roger »
YES,......
WE SCAN!
Offline keizerh
  • Unit(s): none
Re: NEMA output
« Reply #2 on: March 07, 2010, 04:09:35 PM »
ETnSc
AIS works as soon you connect it, on both nmea standard as AIS standard speed.
Didn't check the DSC call
hendrik
Last post June 30, 2010, 10:54:40 AM
by ETnSC
Last post April 09, 2013, 07:37:45 PM
by RayBersch
Last post March 19, 2013, 04:39:20 PM
Last post December 31, 2014, 10:17:26 AM
Last post April 27, 2015, 11:41:16 AM
Last post June 14, 2017, 09:55:22 AM
by Juicegoose
Last post July 13, 2018, 09:40:16 PM
by Beaulieu80
Last post August 13, 2018, 11:01:30 PM
