Author Topic: What comes with the 1199ci HD SI unit when you buy it  (Read 8876 times)
Offline graggy
  • Unit(s): 898C si
« on: April 08, 2015, 05:44:14 AM »
Not sure what all I need to order if I buy the 1199ci HD SI. Does it come with the gimbal mount or cable management system?
Re: What comes with the 1199ci HD SI unit when you buy it
« Reply #1 on: April 08, 2015, 08:43:09 AM »
It has everything you need to start fishing except the battery ...and a mapping card if you want better mapping detail than the Contour XD internal mapping ...
Head unit, power cord, xducer, xducer transom mounting hardware, gimbal mount, cable collector, sun cover ...
GPS antenna is internal ...
« Last Edit: April 08, 2015, 08:46:03 AM by rnvinc »
« Reply #2 on: April 08, 2015, 12:07:24 PM »
What are you meaning by "cable management system"?
The cable collector that Rickie mentioned above holds the connectors of the cables (power, transducer and Ethernet of you buy that cable) so that they are all aligned and plug into/out of the unit at the same time.  There is no cable 'loom' or covering for the rest of the cables, if that is what you are asking about.
Offline graggy
  • Unit(s): 898C si
« Reply #3 on: April 08, 2015, 01:09:37 PM »
Yes the cable collector is what I meant
Last post March 11, 2014, 11:25:48 AM
Last post March 05, 2014, 11:11:11 PM
by MT-ED
Last post July 23, 2014, 01:23:59 PM
by abraquelebout
Last post April 30, 2014, 03:08:02 PM
by tdclaymc16
Last post April 06, 2015, 11:21:27 AM
Last post April 08, 2015, 12:04:37 PM
Last post April 14, 2015, 04:25:20 PM
Last post May 19, 2019, 09:08:24 AM
