Author Topic: Transducer type and mounting  (Read 13594 times)
Offline offroad
  • Unit(s): 1197/ 898
« on: March 03, 2010, 04:03:27 PM »
 Guys
         After a bit of thought l have decided to mount my new 898 on the bow with the ducer on the trolling motor  Question ? can l use/ mount the ducer that comes with the sounder or do l need a different one ?
Offline soretoe
Re: Transducer type and mounting
« Reply #1 on: March 03, 2010, 04:21:02 PM »
Same ducer with a trolling motor bracket
I can also be found at;
« Reply #2 on: March 03, 2010, 09:47:55 PM »
To keep the HD 800kHz Si ability of your unit you will have to use the XTM-9-HDSi-180-T transducer which is the same as the standard transom mount XHS-9-HDSi-180-T transducer that new 898 unit.  The difference between these two transducers is that the XHS version comes with hardware to mount it on the transom and the XTM version comes with hardware to mount it to a trolling motor.  You can call the Humminbird Customer Resource folks at 1-800-633-1468 and talk to them about a transducer exchange.  Another option you may wan to explore is to use your standard XHS-9-HDSi-180-T transducer with an aftermarket trolling motor adapter like the ones that Transducer Shield & Saver or Raptor make.  The reason I mention these is that they not only adapt the transducer for trolling motor mounting but also help protect the transducer from those nasty rocks and stumps out there!
Last post April 06, 2009, 04:39:12 PM
Last post September 29, 2009, 07:58:28 AM
Last post March 15, 2013, 12:41:40 AM
Last post March 15, 2010, 10:24:01 PM
by Llunker
Last post August 23, 2016, 10:05:55 AM
Last post September 27, 2016, 03:40:27 PM
by Mukwah
Last post September 20, 2017, 11:20:34 PM
by fishinman
