Author Topic: Any helpful tips for using side imaging on trolling motor  (Read 11582 times)
Offline dougclark12
  • Avid bass fisherman for 50 years. retired MD.
  • Unit(s): 1197, Onyx
« on: February 19, 2015, 10:41:00 AM »
I recently ordered a new Onix unit(delivery delayed until March). I have move my 1197SI to the trolling motor. Any tips to shorten learning curve for use on TM? Chart speed? I fish vertically a good bit, so the down imaging will help.
Re: Any helpful tips for using side imaging on trolling motor
« Reply #1 on: February 19, 2015, 11:31:02 PM »
https://m.youtube.com/watch?v=vT8nArMGwPA
Keep the chart speed about the same as boat speed ...
Try not to make abrupt changes in TM direction ... As this can cause skewing of the SI image ...
« Reply #2 on: February 20, 2015, 10:53:40 AM »
With SI on the trolling motor you will get the best images by trolling as straight as possible......but you can get good information even if steering......you just have to get past the need for pretty pictures......You can even sit still and scan by turning the trolling motor with the motor off.
Offline kosmo
  • Unit(s): 2 - 998 , 597hd/di
« Reply #3 on: February 20, 2015, 01:20:08 PM »
I'm fixing to confuse things here.rickie is correct about boat speed and chart speed, but he's also wrong.i never run chart speed as slow as what my trolling motor speed would be, on the core units).Come to think of it, I don't do that with my out board either.For me, it's just a waste of time, waiting for the screen to update.i always run chart speed as fast as I can get by with.which is always faster than my boat speed.(you'll like the onix) I chose to use my onix on the trolling motor and keep a 998 at the console.either way would be good choice. Just what fits your needs most.Oh, also, did I say you'll like the onix? I think I did.....you will.....
Offline kosmo
« Reply #5 on: February 20, 2015, 11:09:23 PM »
kosmo makes a good point about Chart Speed ...
There's a balance in how quickly the unit is collecting data vs how often the unit is displaying that data ...
The common sentiment about "Chart Speed = Boat Speed" is just Ballpark relative (to that ratio) to get "in perspective" images ...and this Ballpark relative ratio may even be different across software versions ...
Faster chart speed is basically stretching the echoes across more sonar history ... Which, in the case of fish echoes ... Makes them easier to see and pick out on the SI image ... (A longer elongated fish echo is easier to see than a white dot echo)...
Faster chart speed is not making the unit ping any faster ... It's just "painting" the same echo data into repetitive pixels as the screen scrolls ...
« Last Edit: February 21, 2015, 12:09:51 AM by rnvinc »
Last post February 15, 2011, 04:05:21 AM
by VX70
Last post December 07, 2011, 12:12:48 PM
Last post September 17, 2012, 02:55:39 PM
Last post March 30, 2013, 02:01:11 AM
by wolfs4evr
Last post March 07, 2013, 04:43:32 PM
by Turk
Last post April 09, 2013, 07:20:16 AM
Last post June 11, 2013, 11:28:36 AM
