Author Topic: Humminbird & SD WIFI (is it possible?)  (Read 7279 times)
Offline peterv6i
  • Unit(s): 998ci
  • Software: 4.500
  • Accessories: 998ci
« on: February 06, 2015, 04:50:28 AM »
Is possible to use SD WIFI card inside humminbird unit?
Why I ask this? because in this way you have a wifi connection between unit recorded files and PC.. in this way you can
preview recorded files while unit is still recording something (on the fly).. Or.. you can just transfer files without removing card from the unit..
It's good if you do some research on the terrain. Also  multiple persons can preview same file or other files stored on SD card over wifi.
Offline bigkahuna
  • Accessories: Custom ROV with Imagenex sonar
Re: Humminbird & SD WIFI (is it possible?)
« Reply #1 on: February 06, 2015, 08:53:18 AM »
I haven't tried it but I love the idea!  Don't know if this helps but I found this: http://hackaday.com/2013/08/12/hacking-transcend-wifi-sd-cards/
Looks like it should work, not sure if u could view files and record simultaneously.  HB has an Android app that does that but only works with Ion sonars.
« Last Edit: February 06, 2015, 09:21:47 AM by bigkahuna »
Offline bigkahuna
« Reply #2 on: February 07, 2015, 10:38:08 AM »
Well, after using my best "google-fu" I haven't really found a definitive answer.  My best guess is -yes- this is possible -if- you can find an app that will open the remote SD card and allow you to download files other than picture files.  All the apps I've found so far are limited to working with some cameras and a limited number of file types.
Last post May 03, 2010, 02:21:19 AM
Last post July 14, 2011, 04:30:42 PM
Last post January 20, 2012, 06:49:21 PM
by iliveinakeg
Last post January 03, 2012, 09:13:13 AM
Last post March 07, 2012, 10:31:22 AM
by jazz4627
Last post September 11, 2012, 07:30:05 AM
by gros21
Last post May 24, 2013, 04:09:12 AM
by zeebeest
Last post July 15, 2016, 08:12:02 AM
by Beaulieu80
