Author Topic: 698 transducer mount  (Read 4569 times)
Offline jcotter
  • Unit(s): 385 and 698
  • Software: n/a
  • Accessories: n/a
« on: December 10, 2014, 05:01:17 PM »
where is the best place to mount the transom transducer for Humminbird 698 SI on a 2011 Stratos 285 xl. On the first motor mount transom, the first step below the transom, or the second step below the transom? Thanks.
Re: 698 transducer mount
« Reply #1 on: December 10, 2014, 11:29:46 PM »
Here is some Stratos installation info ...
http://www.bbcboards.net/humminbird-sonar-gps/172975-stratos-boats-installation-images.html
The xducer must be in clean un-aerated water to get un-interrupted imaging ...
Most glass boats mount the SI xducer higher (to be used at idling speed)...and then use a bilge mount shoot thru XP 9 20 with the AS SIDB Y cable (for high speed depth reading)...
High speed reading can be obtained with the stock SI xducer ... But that means mounting the xducer low enough to stay in the water while the boat is up on pad ... Making the xducer succeptable to damage from floating debris ...
« Last Edit: December 10, 2014, 11:34:43 PM by rnvinc »
Last post March 23, 2012, 11:26:00 PM
by NickO
by Brian37075
Last post March 31, 2014, 11:35:56 AM
Last post April 08, 2015, 05:52:30 PM
by Whistler
Last post June 20, 2015, 02:25:23 PM
Last post August 07, 2015, 09:35:56 PM
Last post September 22, 2016, 08:56:51 AM
Last post July 27, 2017, 05:17:45 AM
by fishreed
