Author Topic: ice fishing with 360  (Read 18396 times)
Offline D S
  • Software: 7.5
« on: November 04, 2014, 11:12:55 AM »
considering 360 for ice fishing ,anyont tried it out  on bow mount 360???comments???
ds
stgr
Offline slabbacks
  • Is it Friday yet!
  • Unit(s): 898c HD SI / 859ci HD
  • Software: 6.490
Re: ice fishing with 360
« Reply #1 on: November 06, 2014, 09:12:13 AM »
Dave I'll try and find the link for you...saw one mounted on a bracket on the front of a 4wheeler.  Drop pole with a locking bracket.  Looked like a well build setup and not just some throw together.
Tell them I've gone fishing!
Offline D S
  • Software: 7.5
« Reply #2 on: November 06, 2014, 11:00:47 AM »
slab ,thanks i have seen that post looks intersting but i want to utilize the bow mount  and i'm more interestd in the quality /usefulness on the aquired image on the 360
...not 100% convinced of the  the 1000$  price tag. i currently use my 798.. and find it to be a geat tool with 2d while icefishing  i prefer this to the flasher option as there is a history to look at as well
anyone else  out there try 360 on the ice??
ds
stgr
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #3 on: November 06, 2014, 05:31:23 PM »
Dave something I've notices when we go on our ice trips to MI...at night we use a light for crappie and the underwater camera is rendered useless once the little life starts dancing out front lol.  I think a setup like that would give poor returns as well with any DI SI or 360 unit, just like open water with alot of sediment.
Given the right conditions I have no doubt it would work.  Ice thickness would come into play later in the season.  See why you would want it though...just hole hop to the schools and follow them around  ;D
Offline MT-ED
  • Unit(s): 798ci SI, 1199ci HD SI, 360 BM
  • Software: 6.3
  • Accessories: AS GPS HS, Autochart Pro
« Reply #4 on: November 17, 2014, 11:30:00 PM »
I've already responded to Dave's PM on this, but I'll flup here in case there are other considering this. I used my 360 this past season.....sort of. I only used it while fishing one inpoundment. It contains land locked salmon, and they love to travel in schools, so when you see one......things typically really "light up". I found a good spot in about 30' of water. I love gadgets, so I had 2 cameras set up as well as my 1199 w/ 360. When I had schools working through, as confirmed by the down viewing sonar and the 2 cams set at different depths, I really focused on my 360 to see what showed up. I was disappointed with my results. I can easily see when schools of salmon move through my SI, as well as DI. I was expecting to see something similar with the 360. I did NOT see any fish in the water column of the 360, and even though I could see 100s of fish all around me, the fish reflections seemed to always get lost in the bottom reflection! I tried many configurations, but to no avail.
It seemed that ALL youtube videos of the 360 in use, were in 10' or less of water. I was in 30'. I was wondering if because of the depth, and the necessary additional "power" required to "see" further out, resulted in the "camouflaging" of the fish returns with that of the bottom? If you are in 5' of water, and want to look out to say 15' (3x the depth), this would require far less amplitude of the signal than being in 30' of water and wanting to look out 90'. When I was just using my SI, and watching for schools to traverse the SI curtain, I could easily see fish returns in the water column, and to the sides, using sonar shadows to determine the fish's relative depth. I figured that the amplitude of the signal to reach out 90 with SI would be the same as the 360 (a SI rotating), but I have not yet been able to replicate the quality of my SI on my 360.
Regrettably, personal obligations this summer prevented me from using my 360, so I have no new results to post at this time.
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #5 on: November 18, 2014, 04:08:05 AM »
MT I'm going to send a PM that may help you, so the others know...this is a link to someone that has had some great results with his 360 and he may be able to give some good advise.
If you do find out anything just post back here.   Weather has set in this way so may be many months till you get a chance to test it again.
Offline kosmo
  • Unit(s): 2 - 998 , 597hd/di
« Reply #6 on: November 20, 2014, 03:58:38 PM »
     when you get directly over something, using the 360, it will show all the way round.whitch is kind of cconfusing I think.
« Last Edit: November 20, 2014, 04:01:52 PM by kosmo »
Offline vik33
  • Unit(s): Humm 385 DI/SI
« Reply #7 on: November 21, 2014, 04:52:30 AM »
I use this handmade accessory, just pull line up and down, and know exactly what is the structure under the ice, where my hooks are and is there fish or not 80 feet around:
« Last Edit: November 21, 2014, 04:54:03 AM by vik33 »
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #8 on: November 21, 2014, 05:32:13 AM »
MT, Like I said Kosmo has it down pretty good  ;D
was hoping you would chime in kosmo....sent him your way in a PM
Offline Rickard
« Reply #9 on: November 21, 2014, 08:49:45 AM »
Vik33,
As I have said before, your principle is very clever! I'm trying to give it a name, The Vertical 180 System or SpotImaging or Down-At-The-Spot System. Whatever the best name might be, the system principle should definitly be a candidate for a new level of ice-fishing gear.
Offline D S
  • Software: 7.5
« Reply #10 on: November 21, 2014, 10:45:56 AM »
vik, do u sweep up/down or in a circular motion  with this set up
im interested in utilizing side scan or 360 for ice fishing as well
are u utilizing the si image or down imaging to get your info...
it looks like  the ducer is angled sideways in some pics on your photobucket images ??
i tried rotating si ducer on pole ....didnt seem to get much out of itany suggestions??
ds
stgr
Offline slabbacks
  • Is it Friday yet!
  • Software: 6.490
« Reply #11 on: November 21, 2014, 11:20:38 AM »
Dave that looks to be a Di shot swept front to back or viceversa.  Explains the hump in the image, at least this is the way I'm reading it.  The angle would give a deeper reading at the rear...center would give true depth...and front angle would read deep again.  I'm sure when he checks back in he'll fill us in some more.
I'm surprised that turning the SI ducer didn't give a good shot as long as it was steady.  The guys in the club use SI on the bow and will turn their trolling motor to see what is around them.  They use it alot when spider rigging to find the school of crappie and staying on them.
Offline Rickard
« Reply #12 on: November 21, 2014, 11:56:49 AM »
About a year ago Viktor's method was discussed here: http://forums.sideimagingsoft.com/index.php?topic=3403.msg31133#msg31133
Maybe the thread gives some clues to how it works.
Last post May 28, 2009, 08:45:10 PM
Last post October 28, 2011, 10:40:38 AM
by raricker
Last post January 01, 2012, 06:43:13 PM
by reddog
Last post December 11, 2013, 05:20:47 PM
by jepik
Last post July 21, 2014, 01:19:03 AM
by Trav
Last post February 28, 2015, 05:49:44 PM
Last post March 18, 2015, 06:06:55 PM
Last post January 20, 2021, 09:30:07 PM
