Author Topic: *** HumViewer release 67 ***  (Read 33196 times)
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
  • Accessories: Speed sensor
« on: February 23, 2010, 12:22:39 PM »
Sorry for spamming you with new releases.... >:D
I have made a new release. It contains a bugfix for an potential error if you are loading recordings that have already been loaded in an earlier version.
Also I have added a new view: Down imaging. It should behave more or less as the normal/medium setting in the HB.
It can (as always) be downloaded from here: http://humviewer.cm-johansen.dk
And until Feb. 28 at: http://www.transferbigfiles.com/Get.aspx?id=3ab5097c-f122-4445-b603-581386ec5ddc
/Martin
Version 67 (Release date 23-02-10 17:42)
-NEW: Down imaging view
-New buttons on Contrast/brightness control to quickly auto-correct image
-Slant rate correction is used when calculating position in various Utility tools.
-Bugfix: Fixed bug in configuration when saving waypoint and existing .xml do not contain a <Waypoints> section.
Re: *** HumViewer release 67 ***
« Reply #1 on: February 23, 2010, 04:55:02 PM »
Martin.  working great.  thanks.  I am looking at records robert and I ran on sunday.  wish I had 67 on the laptop at the site.  We will probably be back this weekend.  so will use 67 even more.  thanks. great program.  chuck
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #2 on: February 23, 2010, 05:01:14 PM »
Thanks Chuck
Have a good trip.
/Martin
Offline Llunker
  • Team Llunker
  • Team Llunker
    • Ultimate Lunker Fishing Forum
  • Unit(s): 997c SI
  • Software: 4.75
  • Accessories: SI with in-hull transducer as well
« Reply #3 on: February 23, 2010, 06:48:52 PM »
Martin,
I just got my 997c SI and I havent had a chance yet to install on boat.  But i did DL your  Humviewer--it looks great !!!
Could you or would you please load a TEST file so I can see how the Viewer works?
Llunker
« Last Edit: February 23, 2010, 06:50:43 PM by Llunker »
El Grande Lures Field Staff
« Reply #4 on: February 23, 2010, 07:18:54 PM »
I have set up an ftp account that will allow users to upload files to the server so we can share files easily.  I will post the details in another thread soon.
« Reply #5 on: February 23, 2010, 07:28:18 PM »
great idea. FTP is easy to use.  We can certainly share files more this way.  For the S&R part of the forum I really want to help with recordings and the interpretation of the data. this will make the transfer very easy.   And for new users here will be a place to get files to proatice with and really learn the unit.  Thanks Robert for thinking along these lines.  Chuck
Offline kosmo
  • Unit(s): 2 - 998 , 597hd/di
« Reply #6 on: February 23, 2010, 09:00:45 PM »
thanks
Offline pmburesh
    • Bluegrass Search and Rescue
  • Unit(s): 1197c and 786ci
  • Software: 4.95
  • Accessories: AS Interlink
« Reply #7 on: February 23, 2010, 09:54:17 PM »
For those of us using Vista 64 we cannot open the test file, says it is incompatible with X386 64 bit. Any help with this matter would be greatly appreciated. Has anyone used Humviewer with Vista 64, any problems?
We do this, so others may live
Offline kosmo
« Reply #8 on: February 23, 2010, 09:57:27 PM »
Offline kosmo
« Reply #9 on: February 23, 2010, 10:03:07 PM »
Offline Chiboo
  • SpearFishing
  • Unit(s): Solix 10 MSI+ G3
  • Software: 4.130
« Reply #10 on: February 23, 2010, 11:35:47 PM »
Hi Martin. Once again thanks!!
Whether you can add function of viewing XTF files created by others SI devices?
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #11 on: February 24, 2010, 02:12:43 AM »
I am not sure what test file you are referring to.
I have tested HumViewer on a Windows 7 and it runs there without any problems.
/Martin
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #12 on: February 24, 2010, 02:15:21 AM »
Llunker
Hi Llunker
You can download a test file from http://humviewer.cm-johansen.dk
Just look for the header saying 'Test recording'
/Martin
Offline reso
  • Unit(s): Matrix 37, 997 CSI,Helix 12 Chirp
  • Software: latest
  • Accessories: interlink, high accuracy gps,360 TM
« Reply #13 on: February 24, 2010, 06:47:33 AM »
Great additions to Humviewer! ;D
I was just wondering how the DownImage is generated, since Martin told us in a previous topic it was impossible to include in Humviewer since it is piece of software only known to HB?
Is it like adding left and right sides and presenting it in a 90 degree way, or more complicated?
regards
Reso
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #14 on: February 24, 2010, 06:56:17 AM »
Yes, I know I said that earlier, but Robert helped me in the right direction
It turned out to be as simple as taking an average value of the left and right SI image.
But as I wrote in the release text this is like the Normal/medium setting in the HB. When I get some time I will play with how to get the other settings implemented.
/Martin
Offline reso
  • Software: latest
« Reply #15 on: February 24, 2010, 07:13:55 AM »
Interesting stuff.
I note that when switching in HB from narrow to wide, there is also like an increase in sensitivity, at least that is what it looks to me.
Thanks Martin,
regards
reso
Offline Llunker
  • Team Llunker
  • Team Llunker
  • Unit(s): 997c SI
  • Software: 4.75
« Reply #16 on: February 24, 2010, 04:20:45 PM »
Hi Llunker
/Martin
Tried that with no luck??  DL the File and then when i try and run the EXE file --says it can't run 16bit windows program?  I dunno--could you send me another test file?
Or if anyone has an extra .dat file they don't mind sharing --I would love to look at this viewer.
here is what the file looks like on my Desktop
and here is the error message i get when i click on the file
???? dunno???
« Last Edit: February 24, 2010, 04:48:31 PM by Llunker »
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #17 on: February 25, 2010, 03:47:02 PM »
Hi Llunker
I have uploaded a new version of the HBrec_R0001 to http://humviewer.cm-johansen.dk
Please try to download it and see if you can extract it.
/Martin
« Reply #18 on: February 25, 2010, 03:52:02 PM »
Martin, on the DI screen the lines are 16, 33, etc.  Is there a technical reason for this or could the lines be 10 20 30 etc.  I sure could use the change of lines.  chuck
Offline Llunker
  • Team Llunker
  • Team Llunker
  • Unit(s): 997c SI
  • Software: 4.75
« Reply #19 on: February 25, 2010, 06:19:50 PM »
Hi Llunker
/Martin
Perfect !!!   ;D ;D ;D
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #20 on: February 26, 2010, 04:40:55 AM »
Hi Chuck
I will look into changing it. The reason for 16,33 is that I was lazy. It is just the meters converted into ft.
/Martin
Offline dybvad417
  • Wreckhunter in the Kattegat, Denmark
  • Unit(s): 987 Cx SI
  • Software: 4.750
« Reply #21 on: February 26, 2010, 05:57:26 AM »
Hi Martin
" The reason is that I was lazy"
We have to do something  about that  ;D
Gert
Offline Llunker
  • Team Llunker
  • Team Llunker
  • Unit(s): 997c SI
  • Software: 4.75
« Reply #22 on: February 26, 2010, 05:59:12 AM »
Dank Martin für alle, die Sie mit diesem Programm getan haben.  Es ist zu jeder hier sehr vorteilhaft.
Danke
Schupo
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #23 on: February 26, 2010, 07:58:51 AM »
Hey Martin!
"The reason is that I was lazy"
Huh???? If you were lazy, there would be no Humviewer!
I think I speak for all of us here: What you have done for us is priceless!
Thanks again and always thanks whenever you come out with news  ;)
Harry
YES,......
WE SCAN!
« Reply #24 on: February 26, 2010, 08:58:32 AM »
I see the connection with meters.  when you get a chance a scale that gives more would get more actual bottom to top definition. dont know if that means 30 40 50 60 or 10 20 30 40.  what ever give more actual bottom to surface size.    By the way.  Great work on what you do.  "LAZY"  I really doubt that. And look how much you got paid (or is that diid not get paid)  Thanks Martin for your time and knowledgre so that others may have an advantage of your program in determining what is it we are seeing underwater.  Chuck
Offline stillbear
  • Stillbear
  • Software: 5.840 5.700- 4.0
« Reply #25 on: February 26, 2010, 10:33:54 AM »
Thanks Martin works great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!     Gary
Last post February 05, 2010, 04:46:14 AM
by mrj9600
Last post June 06, 2010, 10:49:18 AM
by pascalfromfrance
Last post March 03, 2012, 03:59:47 PM
Last post April 24, 2013, 02:29:51 PM
by Jolly Roger
Last post April 29, 2014, 10:44:38 PM
by ksc
Last post March 23, 2015, 04:13:56 PM
by sfw1960
Last post May 05, 2015, 09:54:10 AM
by FlyFisher SLC
Last post August 29, 2015, 01:30:43 PM
by Blackhawk19
