Author Topic: Lakemaster & XD maps mesh together ?  (Read 7688 times)
Offline Erino
  • Unit(s): 1199 si, 1159, 859 combo, Helix 7 G2n
  • Software: 7.65, 2.04 & 2.15
  • Accessories: I-link, ethernet hub, Terrova 80, MK-315
« on: August 19, 2014, 09:26:55 AM »
Is there any way to mesh together a lakemaster map with the built in XD map.
I was fishing the northern part of Lake of the woods Ontario.  Lakemasters chip does not cover 100% of the lake.  The main channels are charted for parts of the lake but not all. So you end up running blind in a lot of those areas.  The base XD map at least gives you some information (sounding depths) for the entire lake.  I wish the 2 could mesh so when your in area where the lakemaster chip gives zero information it would revert back to the XD map.
Re: Lakemaster & XD maps mesh together ?
« Reply #1 on: August 19, 2014, 10:10:30 AM »
No there is not.  You either select to use the ContourXD maps or a map card from one of the memory card slots.
The only mesh option would be if you created your own AutoChart maps.  There is a transparency layer you could use for that with the ContourXD (or LakeMaster) maps.
Last post January 11, 2010, 10:55:19 PM
by lcookie
Last post May 30, 2011, 02:04:13 PM
by stillbear
Last post March 20, 2013, 12:30:05 PM
Last post April 13, 2014, 12:11:07 PM
by john cook
Last post September 09, 2014, 10:12:19 PM
by Kenneth_v
Last post March 03, 2015, 09:15:51 AM
Last post December 07, 2015, 08:40:10 AM
Last post April 27, 2018, 09:38:11 PM
