Author Topic: linking 798c si to 1198 or 1199  (Read 13124 times)
Offline docsonnys
  • Unit(s): 798csi,718
  • Software: ver5.45
  • Accessories: interlink
« on: August 16, 2014, 05:27:43 PM »
I have a 798 c si unit and will purchase a 1198 or 1199 unit soon.  Can I link there two to share waypoints and maps.  I have an interlink unit.
Offline Trout Bum
  • Unit(s): 958 HD, 788 ci HD
  • Software: 6.640
  • Accessories: aux speed & temp, ethernet
Re: linking 798c si to 1198 or 1199
« Reply #1 on: August 17, 2014, 08:33:14 AM »
It would be best to use Ethernet.
The 798 and 1199 would need the optional plug in adapter to change the Ethernet round plug to the correct plug for the unit.
The 1198 would be a direct plug in and you would only need an adapter for the 798.
2013 Lund Rebel 1650 XL Sport
60 hp Mercury 4-stroke
Humminbird 998c HD SI, 958c HD & 788ci HD
Minn Kota Terrova w/i-pilot
Offline docsonnys
  • Software: ver5.45
« Reply #2 on: August 17, 2014, 12:27:46 PM »
Thanks Trout Bum.
« Reply #3 on: August 17, 2014, 02:56:14 PM »
If the unit is the 798 HD model ...it is Ethernet compatible...
If the 798 does not have HD in the model name...it is only Interlink compatible...
Interlink will copy and transfer waypoint data from unit to unit...
Ethernet will only "share" waypoint data...with both units powered on and set to "Share Waypoint"...
Neither Interlink nor Ethernet will share maps...except Ethernet ONIX to ONIX and ION to ION ...
« Last Edit: August 18, 2014, 07:58:07 AM by rnvinc »
Offline Trout Bum
  • Software: 6.640
« Reply #4 on: August 17, 2014, 06:50:19 PM »
I don't believe that Interlink works with the 1199, but not sure.
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #5 on: August 17, 2014, 07:26:16 PM »
It DOES NOT.
« Reply #6 on: August 18, 2014, 01:19:01 PM »
Depending on the software version in the 1198 unit it may or may not communicate with the 798 unit through the InterLink.  They both need to be running the same level (number before the decimal point) software.
Last post December 03, 2012, 12:38:53 PM
Last post January 07, 2014, 12:11:19 PM
Last post July 01, 2014, 02:12:18 AM
by Nitro78
Last post September 03, 2014, 12:03:57 AM
by mike82
Last post September 21, 2014, 09:25:37 PM
by sfw1960
Last post December 10, 2014, 09:17:05 PM
by beertech
Last post March 04, 2015, 09:10:07 PM
Last post April 02, 2017, 10:25:20 PM
