Author Topic: NMEA between 947c and VHS not working...  (Read 9684 times)
Offline salika
  • Unit(s): 947C
  • Software: 4.75
  • Accessories: GPS, Speed/Temp, 3D Sonar
« on: July 21, 2014, 11:22:12 PM »
Hello - I am trying to connect my Humminbird 947C to my West Marine VHS 580 radio so the radio can receive the boats current GPS coordinates, so far - no love - the radio makes no indication it is connected to anything.
On the Humminbird I have connected Power (of course), Speed/Temp, GPS Antenna, and 3D Transducer, the four plugs grouped together.. The 947C has NMEA Enabled in the Advanced menu, the GPS Wire to the antenna has a pig tail with a RED / WHITE / BLACK wires under a cap. The 947C is running software version 4.75.
The radio has two versions of its manual out there showing the NEMA+ wire as being either Yellow or Green and the NMEA GND as being the bare wire. I have connected both Green and Yellow and neither has worked.
I have made these connections;
   Humminbird White (NMEA+) to WM580 Yellow - not functional
   Hummingird White (NMEA+) to WM580 Green - not functional
   Humminbird Black (NMEA GND) to WM580 Bare
   Humminbird Red - not connected.
Per the discussion here ; http://forums.sideimagingsoft.com/index.php?topic=4014.0
I was thinking about trying the AS-HHGPS Cable in the second accessory port labeled #4 on page four of the 947C Manual. I was then going to connect AS-HHGPS White cable to the WM580 Yellow.
Is this the right thinking or should I be doing something else.
Thanks - Steve
« Last Edit: July 21, 2014, 11:27:02 PM by salika »
Re: NMEA between 947c and VHS not working...
« Reply #1 on: July 22, 2014, 08:30:22 AM »
Welcome to the Humminbird Side Imaging Forums salika.
Your wiring connections between your 947 and the VHB (?) radio sound correct.  Maybe you can find someone else with a Humminbird unit that would allow you to plug their unit into your connections to test it with?
Offline salika
  • Unit(s): 947C
  • Software: 4.75
« Reply #2 on: July 24, 2014, 03:45:31 PM »
Hey Greg - thank you for the reply. Unfortunately I do not know anyone with a Humminbird unit I can try in place. I will be able to solder up a RS-422 cable and plug it into my laptop and read the 4800 baud / 8 bit / no-parity serial line that is coming out of the 947c. I will try that next week.  I am curious to three things I have read in other posts;
a) There is mention that if the Anttena has the older RED - WHITE - BLACK wires I might may need to upgrade to an antenna with the GREEN - YELLOW - BLACK wires, does this make sense?
b) There was also talk that this old NMEA-0186 unit output the UP command in the output sentence and this may make the output simply incompatible with some inputs.
c) The last is that there is a reason to splice into the antenna wires and directly attach to some other wire in that bundle.
Are any of these other suggestion applicable to my problem? I am still going ahead with the serial connection to make sure the 947C is outputting data.
Thanks - Steve
« Reply #3 on: July 28, 2014, 11:50:36 AM »
I don’t know if they apply to your situation or not Steve.  All three reference the same thing: the NMEA 0183 sentence prefix that we use.  With the older Red/White/Black wired GPS Receiver connection at the NMEA pigtail; the output was with an $IN prefix which most devices can use.  The newer GPS Receivers with the Green/White/Black wire connection have an $GP NMEA sentence prefix which some devices require.  This can also be taken from the older Red/White/Black wired GPS Receivers by splicing into the main cable (not the NMEA pigtail) as it has the Green wire connection there.
Last post March 27, 2010, 02:58:30 PM
Last post April 21, 2010, 02:59:52 PM
by netman
Last post June 25, 2011, 10:11:07 AM
by Daz
Last post November 18, 2011, 12:32:34 PM
Last post October 19, 2011, 10:12:11 AM
Last post March 23, 2012, 03:23:06 PM
by rheykoop
Last post October 08, 2012, 02:14:12 PM
Last post April 15, 2013, 02:19:27 PM
