Author Topic: zoom in and out speeds  (Read 10886 times)
Offline vkjanzen
  • Unit(s): 798ciHDSI
  • Software: not sure
  • Accessories: none
« on: June 27, 2014, 07:59:05 AM »
I have a 798ciSI unit - has internal GPS.  I recently fished with another who had one of larger screened units and he could zoom in and out and the screen changes were almost instant.  Mine seems to 'load' and takes time.  He had external GPS puck - would this make a difference.  Anyone using external GPS w/this unit - pros/cons?
Thanks.
Re: zoom in and out speeds
« Reply #1 on: June 27, 2014, 10:10:32 AM »
Welcome to the Humminbird Side Imaging Forums vkjanzen.
No.  The difference you are seeing is in the processing power of the larger unit.
Offline vkjanzen
  • Accessories: none
« Reply #2 on: June 27, 2014, 11:04:12 AM »
Greg - thank you for the quick response.
Are the new 800 series units faster?
Is there any advantage to using EXTERNAL GPS puck?
Thanks.
« Reply #3 on: June 27, 2014, 11:35:36 AM »
Yes, the new 800 series units are faster.
The main two advantages of an external GPS Receiver is that it can be mounted closer to the transducer, which minimizes any user controlled error for waypoints, and it can be sent in for service without having to do without your sonar unit.  Another advantage would be that it should be able to work better in a high electrical noise environment versus the internal.
Offline Beaulieu80
  • Unit(s): 798CXI HD SI COMBO
  • Software: 7.68
« Reply #4 on: August 08, 2014, 08:18:50 AM »
larger unit have faster CPU, like my 798ci HD SI, it think it has a 245Mhz CPU inside.
Offline sfw1960
  • Bringer Of The 'Bird
« Reply #5 on: August 08, 2014, 12:39:26 PM »
265 as opposed to a 550 dual core I believe .......
« Last Edit: August 08, 2014, 12:40:39 PM by sfw1960 »
Last post March 23, 2010, 09:21:30 AM
Last post March 07, 2011, 04:54:20 PM
Last post June 24, 2011, 06:57:15 PM
by Salmonid
Last post June 08, 2011, 10:28:04 AM
Last post April 28, 2012, 11:45:06 PM
by LocDown
Last post April 09, 2013, 05:19:58 AM
by reso
Last post May 12, 2014, 12:11:13 PM
by Ronny
Last post March 01, 2015, 07:30:27 PM
by Bayou Basser
