Author Topic: 899ci hd si problem with Low Voltage?  (Read 7401 times)
Offline Rwe0659
  • Unit(s): 899 CI HD SI
  • Software: 7.650
  • Accessories: Minn Lota RipTide Ipilot
« on: June 01, 2014, 06:50:16 PM »
I have a 899ci hd si with blurred screen (hoping the latest software release fixes that). I am also getting a low voltage message after I am out for an hour or two, I push exit and it clears and does not come back up? Any ideas? Thanks in advance!
Re: 899ci hd si problem with Low Voltage?
« Reply #1 on: June 02, 2014, 11:34:21 AM »
Welcome to the Humminbird Side Imaging Forums Rwe0659.
Is this a new installation or just a new problem?
How is your 899ci HD Si unit connected to the battery: new wires straight from the unit to the battery or are you using the boat’s wiring?
Is the 899ci HD Si unit wired to the cranking battery or one of the trolling motor batteries?
Go ahead and check all of the electrical connections for any that are loose or corroded.  Don’t forget the fuse, fuse holder and battery terminal connections here.
Low Voltage
Started by spes 798c SI
Last post January 27, 2013, 03:23:36 PM
by strawdg
Last post April 09, 2013, 10:40:21 AM
by jepik
Last post February 11, 2014, 05:20:38 PM
by jjbch
Last post March 21, 2014, 10:05:46 PM
by Brismith3
Last post March 24, 2014, 03:13:28 PM
Last post April 20, 2014, 12:40:42 AM
by rsouza3
Last post April 22, 2014, 11:10:14 AM
Last post May 02, 2016, 09:57:07 PM
by born 2 fish
