Author Topic: Turn 83khz off  (Read 10680 times)
Offline jbrady2852
  • Unit(s): 999ci HDSI, 788ci DI
  • Software: 7.020
Turn 83khz off
« on: May 30, 2014, 08:36:46 PM »
Saw a couple of recommended settings regarding Turn 83khz off for faster processing and recording.  Going through the menu items on the 999ci SI I am not seeing an option to turn it off.  I only see an option to change the sensitivity.  Can someone point me in the right direction.
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: Turn 83khz off
« Reply #1 on: May 31, 2014, 08:19:08 AM »
I dont have a 999 but look under the Sonar tab and choose 200 khz should be an option.
Re: Turn 83khz off
« Reply #2 on: May 31, 2014, 10:23:43 AM »
Press "Menu" 1 time ...opens Xpress Menu...(most common settings for that view)...
Press "Menu" 2 times...opens the Main tabbed menu...
Sonar tab should be the 2nd tab from the left...
Offline Trout Bum
  • Unit(s): 958 HD, 788 ci HD
  • Software: 6.640
  • Accessories: aux speed & temp, ethernet
Re: Turn 83khz off
« Reply #3 on: June 01, 2014, 12:07:50 PM »
Go to the Main Menu/Sonar tab and on the Beam Select box choose only 200. The choices are 200 (default), 83. 200/83.
2013 Lund Rebel 1650 XL Sport
60 hp Mercury 4-stroke
Humminbird 998c HD SI, 958c HD & 788ci HD
Minn Kota Terrova w/i-pilot
Re: Turn 83khz off
« Reply #4 on: June 02, 2014, 10:35:52 AM »
+1
Last post May 22, 2012, 03:52:12 PM
Last post November 08, 2011, 10:16:36 AM
Last post May 06, 2012, 11:47:03 AM
by wolfs4evr
Last post January 28, 2013, 06:18:05 PM
Last post March 27, 2013, 09:38:23 PM
by Dows3r
Last post July 09, 2013, 02:20:58 PM
Last post March 23, 2014, 10:52:56 AM
by chuck41
Last post May 03, 2016, 11:42:30 PM
by fishreed
