Author Topic: Update 6.3 wipes out the gps function on my 997  (Read 8751 times)
Offline billius
  • Unit(s): 859di, 899disi
  • Software: ?
  • Accessories: interlink (doesn't work)
« on: May 10, 2014, 12:42:54 PM »
I recently had to send my 997 to the factory as it was not reading depth. I got it back and they had downloaded software 6.3 I believe it is. That wiped out my gps capabilities. A few years ago, I updated to 6.3 and the same thing happened. HB has no idea why its happening. So I luckily had a copy of the old 4.9 or some such thing, downloaded it, now my gps is functioning, but I have no speed showing.  Any ideas?
Offline DiveExplorer
Re: Update 6.3 wipes out the gps function on my 997
« Reply #1 on: May 11, 2014, 02:27:06 PM »
I don´t know why it does not work with your unit, it works with mine 997. But I don´t use, when I use 6.3 the side scan picture is not clear enough, I don't know if anyone as experience with that also.
I have install most of those updates, I find them some of them work well others seems something wrong or some conflicts in the software.
I use 5,450, I have no problems with that, and I can use the recordings with no problems with SI software's.
Offline billius
  • Software: ?
« Reply #2 on: May 11, 2014, 05:48:58 PM »
Thanks for the response. I tried to download 6.3 again, same result, it wiped out my gps functions, it was like the unit has no gps on it at all. So,  I downloaded the original 4.95 I think it is...now everything works just fine.  Go figure.  Can't decide whether to send it back to HB again, and be without it for another week, or just forget it.
« Reply #3 on: May 12, 2014, 12:37:49 PM »
billius,
Which GPS Receiver are you using with your 997 unit?
Offline billius
  • Software: ?
« Reply #4 on: May 12, 2014, 09:46:52 PM »
Do you mean what gps antenna I am using?  Its the one that came with the unit when it was new. A dealer installed it for me prior to my buying the boat.  I can check it tomorrow to see what number or name is on it.
« Reply #5 on: May 13, 2014, 10:00:49 AM »
No need to billius, I just wanted to make sure it wasn’t one of the newer GPS Receivers.  That should not be happening but if it can back from Humminbird like that I would contact them about getting it fixed under the service warranty before it expires.  You may have to send in the GPS Receiver along with it this time.
Offline billius
  • Software: ?
« Reply #6 on: May 13, 2014, 11:13:40 AM »
I appreciate the replies and advice.  It works well since I installed the old 4.95 software, but it should work with the  new software as well. I will give HB a call and see what they say. I have 90 days for their recent work to be warrantied.  I just hate to lose the use of it now...this is prime bass fishing season here in central Indiana.  Bill
Last post July 16, 2010, 02:55:07 AM
by equinox
Last post June 04, 2011, 10:54:46 PM
by bigbass
Last post February 23, 2013, 10:33:35 PM
by busterboy2238
Last post May 30, 2013, 05:14:51 PM
by RBrad
Last post December 26, 2013, 01:49:58 PM
Last post May 12, 2014, 12:11:13 PM
by Ronny
Last post July 09, 2015, 11:24:06 AM
by Carver
Last post February 04, 2020, 09:46:17 PM
