Author Topic: Advantages/Disadvantages changing from AS GRHA to AS GPS HS  (Read 12426 times)
« on: April 09, 2014, 12:33:08 PM »
Folks,
I understand that the AS GRHA is accurate to 1 meter,
and that the AS GPS HS is accurate to 2.5 meters.
I am currently using the GRHA.
I also understand, that if I get a 360, I may HAVE to use the HS,
but that is not written in stone yet.  Probably, no one knows yet, what the
360 will do if it's hooked to a GRHA.
I haven't gotten a 360 yet, and I want to keep my GRHA.
It might work with the 360.  I am most certainly going
to try it.
Let's say, I do have to switch over to the HS puck.
In real world use (Navigating, Marking Waypoints), will
the reduced actual (if any), gps accuracy matter that much?
What advantages/disadvantages would I get with switching.
« Last Edit: April 09, 2014, 12:36:50 PM by ITGEEK »
Re: Advantages/Disadvantages changing from AS GRHA to AS GPS HS
« Reply #1 on: April 10, 2014, 11:44:47 AM »
I think the 360 needs the heading sensor info to accurately place waypoints on the 360 image...
Greg can probably tell us if there are other requirements needed from the AS GPS HS antenna for the 360 to operate correctly...
« Last Edit: April 10, 2014, 11:46:37 AM by rnvinc »
« Reply #2 on: April 10, 2014, 01:00:48 PM »
That's the only one that I know of Rickie.  It has to know what direction everything is so it can show the data in the correct area of the unit's display.
« Reply #3 on: April 10, 2014, 06:54:07 PM »
Well this raises an interesting question...especially maybe for someone like ITGEEK...interested in the 360...
Can the AS GRHA work on the 360 ...but just not be able to mark accurate waypoints in the 360 view...??
Meaning... when the 360 is set to SI/DI (no spinning beams)...would the AS GRHA be accurate at waypoint marking...??
Hmmmm...
« Last Edit: April 10, 2014, 06:56:36 PM by rnvinc »
Offline Rotus623
  • Software: 6.49
« Reply #4 on: April 10, 2014, 11:38:36 PM »
So Rickie, when are you going to become a software/hardware engineer over at HB?  ;D
« Reply #5 on: April 13, 2014, 11:00:56 PM »
As soon as Greg can sneak me in...lol...
Last post January 12, 2010, 11:07:15 PM
Last post April 04, 2010, 08:11:21 PM
by stillbear
Last post August 19, 2010, 08:44:35 PM
by DougV
Last post December 15, 2010, 06:34:42 PM
by tellicorick
Last post June 12, 2013, 10:07:50 AM
Last post March 05, 2014, 02:27:40 PM
by Rotus623
Last post March 02, 2015, 03:50:15 PM
by Trytoofish
Last post February 02, 2018, 08:55:12 AM
by N9Phil
