Author Topic: two units at once  (Read 7620 times)
Offline MT-ED
  • Unit(s): 798ci SI, 1199ci HD SI, 360 BM
  • Software: 6.3
  • Accessories: AS GPS HS, Autochart Pro
two units at once
« on: February 25, 2014, 11:26:58 PM »
I've read where some folks have one unit on their console, and one on their trolling motor. Can you have two units on one boat with two transducers operating at the same time without them interfering with each other? Thanks in advance.
ed
Offline bobcoy
  • Unit(s): 1197 & 1198
  • Software: 6.640 & 7.670
Re: two units at once
« Reply #1 on: February 26, 2014, 08:13:14 AM »
If both units are putting out a ping at the same frequency you will get cross talk. If networked with ethernet both can display the same transducer therefor eliminating the cross talk. In less than 20' deep you probably won't have any problem with cross talk.(has to do with the cone diameters overlapping)
« Reply #2 on: February 26, 2014, 02:11:05 PM »
It also has to do with how sonar reflective the bottom of the lake/river is as well.
Basically, there is no way to guarantee that you will or will not get sonar cross-talk (interference) if you have more than one unit transmitting and receiving on the same frequency(s) on the boat at the same time.
If you try this and see sonar cross-talk; try turning on and up the Noise Filter menu.
by garinis33
Last post June 21, 2012, 09:12:07 AM
Last post December 27, 2013, 03:16:33 PM
by RuffWood
Last post April 22, 2014, 01:09:24 PM
by skeester
Last post July 13, 2014, 08:04:51 PM
by Beaulieu80
Last post July 22, 2014, 09:46:16 PM
Last post August 13, 2014, 05:51:16 PM
by Rotus623
Last post August 25, 2014, 01:39:00 PM
