Author Topic: transducer compatablity  (Read 4340 times)
Offline castle rock clown
  • Unit(s): 788c, 788ci HD, 999si
  • Accessories: Link, AS GPS HA, AS GR50, weathersense
« on: February 24, 2014, 08:48:08 PM »
I bought a 788ci hd, it is not a di. I've located an XTM WS3D transducer, is this the wideside transducer, and is it compatable with my 788. Thanks.
« Last Edit: February 25, 2014, 10:40:49 AM by castle rock clown »
Re: transducer comparability
« Reply #1 on: February 25, 2014, 10:53:08 AM »
Yes and yes.
That is the trolling motor mounted versions of the WideSide transducer for the old WIDE 3D series of units that we used to manufacture.  It will work with your 788 unit but you should have an extra cable you will not need.  Remember to change your Transducer Select menu when using it.
Re: transducer compatablity
« Reply #2 on: February 25, 2014, 11:14:28 AM »
Are you saying that the y cable that comes with the transducer can be put on the shelf and collect dust forever, and that the single feed cable can just be directly installed into the matrix head?
« Reply #3 on: February 25, 2014, 01:36:31 PM »
Yes I am.  If I am remembering correctly; the extra cable was for the 3D units that needed the 2D sonar to come into the unit on a separate connector.  Since you won’t need to do that the cable will not be used.  Just plug it up, set the Transducer Select menu and go!
« Reply #4 on: February 25, 2014, 02:26:29 PM »
Thanks, you guys are an amazing resource. On my river boat I am mounting twin 700 units side by side at the tiller. One will be connected to the trolling motor at the bow supporting the wide side transducer and the other 788 will be connected to a transom mounted quadrabeam. I can't wait to get back on the water...the fish won't stand a chance.
« Last Edit: February 25, 2014, 10:15:43 PM by castle rock clown »
Last post June 13, 2009, 03:44:25 AM
Last post May 19, 2009, 05:08:38 PM
by inshorecatch
by Sonshine Fishing
Last post February 24, 2010, 07:39:14 PM
by Brian37075
by jgcox6
