Author Topic: Operating a HB with a transformer  (Read 8305 times)
Offline Bayou Basser
  • Unit(s): Helix 5 Chirp DI GPS G3, Helix 7 Chirp M
  • Accessories: None
« on: February 04, 2014, 10:18:53 AM »
Hey everyone, I have a 'plug in the wall type' transformer that has a rated output of 12v and 700mA.  Would this be safe to operate a 596c HD DI unit that is listed as having a current draw of 400mA?
Re: Operating a HB with a transformer
« Reply #1 on: February 04, 2014, 10:33:55 AM »
I would think so.  The "wall wart" outputs more current than the 596c HD DI unit draws so you should be fine.
« Reply #2 on: February 04, 2014, 01:39:33 PM »
Other than initial surge at power on it should operate fine. At this small of draw 700 should handle the surge. Check the transformer for "heating" as it is used. Warm is normal during usage but if it gets hot then discontinue and go for a bit larger one..
chuck
  • Accessories: None
« Reply #3 on: February 05, 2014, 04:30:10 PM »
Thanks Greg! The "wall wart'', as you called it, worked great.  Chuck, the transformer got a little warm as you said but everything worked fine.   I don't want to insult anyone's knowledge of electronics but all I had to do was watch for the correct polarity when I wired it up.
Quentin
Last post January 18, 2013, 04:18:38 PM
Last post April 18, 2013, 03:53:24 PM
by Rotus623
Last post July 06, 2013, 01:01:51 PM
by theflatlander
Last post March 12, 2014, 01:12:41 PM
by Bayou Basser
Last post August 14, 2014, 03:54:13 PM
by Beaulieu80
Last post February 13, 2015, 09:43:07 PM
by jworks
Last post March 04, 2015, 05:35:32 AM
by Sasch
Last post December 18, 2020, 10:28:00 PM
