Author Topic: Thru Hull  (Read 3783 times)
Offline Boots
  • Unit(s): 998,788, purchasing twin 1199's
  • Software: NA
  • Accessories: Thru Hull trans??
Thru Hull
« on: January 28, 2014, 07:57:44 PM »
Is it recommended to have thru hull option on Rangers when boat is being built for 199 si di for side and down imaging?? I there a smaller transducer for Minn Kota 112 mount for side and down?? If so what are the numbers?
Re: Thru Hull
« Reply #1 on: January 30, 2014, 02:00:53 PM »
Welcome to the Humminbird Side Imaging Forums Boots.
What model unit are you asking about this for?  That may be a typo on your part as we do not have a “199 si di” model.
If you were meaning the 1199ci HD Si model unit, then yes I recommend adding the XP-9-20 inside-the-hull (aka: “Thru Hull”) transducer and the AS-Si-DB-Y transducer if that is a planning/lifting type hull on your Ranger.
There is a somewhat smaller Si transducer that is made for the trolling motor (XTM-9-HDSi-180-T) but you will lose the 800kHz Si/Di sonar capabilities if you use it.
Last post May 15, 2010, 10:46:49 AM
by TMcG
Last post December 05, 2011, 01:23:52 PM
Last post November 23, 2012, 09:53:47 PM
by BCLII
Last post April 24, 2013, 01:55:50 PM
by fishesman
Last post November 19, 2013, 09:41:16 AM
by 220BayFox
Last post February 05, 2014, 12:45:20 PM
by Chicken Joe
Last post September 12, 2014, 09:58:18 AM
Last post March 09, 2015, 04:10:44 PM
by TheSavant
