Author Topic: HB 997 sonar imaging gotten worse over time  (Read 13406 times)
Offline eddy6053
« on: November 17, 2013, 01:58:01 PM »
When I first got my HB 997 (09) it worked great, one of the things I loved was being able to watch my jig on the screen, a couple of years later I noticed it was harder to see and now can't see it at all. The si still looks good, it just appears to be the sonar. I have tried different settings and gone back to default. Could the contact pins have gotten corroded? They look normal... If you wanted to clean the pins, would something like Tarnex work. Any idea's?
Offline JDX
  • Unit(s): 788 ci 898HD SI 899HD SI
Re: HB 997 sonar imaging gotten worse over time
« Reply #1 on: November 17, 2013, 08:57:11 PM »
I just say that if your cleaning any electrical contact you can use an electric parts cleaner. I always use CRC brand and have never had any corrosive issues to plastic. I would also make sure you didn't pinch any of your wires.
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #2 on: November 17, 2013, 09:29:02 PM »
Have you updated from the original software level?
The third update level I did, the image was not as good as the previous two.I went back one level and everything was OK.
Another possibility is the transducer is failing.
         Mike
« Reply #3 on: November 18, 2013, 12:12:02 PM »
eddy6053,
I would try cross-testing your 997 unit with someone else that is running a Humminbird unit.  This does not have to be another 997 unit or even an Si unit as your concern is with the 2D sonar.  Just don’t test it with a DI model unit as they use a different 2D sonar.
My $$$ would be on the transducer starting to fail as well.
Offline eddy6053
« Reply #4 on: November 18, 2013, 05:33:02 PM »
I'm going to try a differant transducer on Tuesday. Is there a set time a transducer is usually good for? I know it's not set in stone, but average transducer life? Is there something that causes them to fail faster? I've never had a problem with any of the others I've had.
« Reply #5 on: November 19, 2013, 11:09:43 AM »
I don’t know that there is a set lifespan for a transducer.
Just like anything else: extreme physical and temperature stresses that the transducer gets exposed to would speed up its failure.
Offline jgollihar
  • Unit(s): 1197, 998
  • Accessories: interlink
« Reply #6 on: December 13, 2013, 06:48:56 PM »
I strongly believe it is the updates causing the loss of quality of the 2D sonar. Humminbird has lost and will continue to lose customers because of this issue. My 1197 unit 2D is terrible and looks like a 1980's dot matrix. I have watched it get worse with every update. I know it is not the transducer because my non updated unit looks fabulous. An obviously there is nothing wrong with the unit because I sent it to Humminbird and 70 dollars later was told it was fine. I myself am finished with Humminbird.
Offline eddy6053
« Reply #7 on: December 14, 2013, 10:31:15 AM »
I didn't get a chance to take the boat out...I'm in Minnesota, and in late Nov or Dec you have to pick your days, and find a landing that's not iced in. When it gets close to 40 degrees I don't mind getting out but the wind was gusting to 30mph....kinda takes the fun right out of it. As far as the updates ... that could be, is there any going back in updates?
Offline strawdg
« Reply #8 on: December 14, 2013, 11:05:22 AM »
Yes you can go back within reason, don't know where the 'don't go past point for the 997 is'..... My 998 has been taken back to 6.49 where it will stay until HB (hopefully) fixes the 2D problem.
Wish I didn't have to stay at 6.49 because I would like to go with the Ipilot link BUT will not invest more money till there is a fix.
Straw
« Last Edit: December 14, 2013, 11:07:10 AM by strawdg »
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #9 on: December 14, 2013, 11:39:38 PM »
eddy6053
      Near the top of the this page is a link to the downloads section. Click on that.
      On that page click on the Sub Category in the Humminbird Firmware/Software Updates that applies to your unit.
      Robert and Chuck have posted different levels of updates. They can be downloaded to a blank SD card.
      It is recommended not to go back past the level that originally came on your unit when new.
                  Mike
« Reply #10 on: December 15, 2013, 02:56:12 PM »
What revision are you running now?
Offline eddy6053
« Reply #11 on: December 15, 2013, 08:39:56 PM »
I'll have to run out and check...but I think it was the down imaging update
« Reply #12 on: December 15, 2013, 09:15:48 PM »
Sounds like you're revs are way older than the software revisions that caused some imaging problems.
Not up to speed on the 997 revs, but the 6.310 revision is probably the best.....6.49 would be better if it is available for the 997.  I suspect your revisions are well below these.
« Reply #13 on: December 18, 2013, 03:14:52 PM »
The last software version released for the 997 units was 6.300
Last post January 01, 2010, 06:37:51 PM
by Teamleader
Last post April 15, 2011, 10:39:15 PM
by dvanpham
Last post December 26, 2011, 01:27:25 AM
by Roddy
Last post February 24, 2012, 01:42:20 PM
by lajo1976
Last post October 26, 2012, 12:52:57 PM
by Roddy
Last post September 16, 2013, 07:29:01 PM
by adriank
Last post June 11, 2015, 10:58:47 PM
by Bubba Canuck
