Author Topic: Pixels seem bigger on 2D  (Read 4681 times)
Offline Poorman
  • Unit(s): 898c
  • Software: 6.740
« on: November 02, 2013, 07:34:16 PM »
My pixels are bigger on my 2d now. Not sure what I did to cause this. I am thinking the update did it. The smaller pixels sure make for a better looking picture. Does anyone have a clue what I need to do to change this back. I am running in clear mode.
Re: Pixels seem bigger on 2D
« Reply #1 on: November 02, 2013, 10:27:07 PM »
There are many reports of degraded 2d in the new versions...
If you know what version came on your unit..you can back load that version...
http://forums.sideimagingsoft.com/index.php?topic=85.0
If that version is not in the Software Download subforum...you can contact HB for the bin file...
It is not recommended to load a version of software farther back than what came on your unit...
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
« Reply #2 on: November 03, 2013, 12:31:02 AM »
+1
The 2D problem with the newer software is that the pixels become larger and larger as the Chart-Speed increases.
You could run CS = 1 or 2 . . .  More so on the older HB units with less processor, xxx7 etc.
I restored my units to previous S/W levels...
Offline Poorman
  • Unit(s): 898c
  • Software: 6.740
« Reply #3 on: November 03, 2013, 04:28:53 PM »
That is a tough call. With the latest upgrade I have a clearer picture on my  SI. This came about when I installed the 6.40. Before this upgrade I had the 6.18. I now have the latest 6.74. I like to run my 3d at a faster rate. It helps me recognize stripers better.
Last post July 24, 2013, 12:54:05 AM
by LittleGazoo
Last post April 17, 2020, 05:13:39 PM
by Philip Brown
