Author Topic: Recording on a 598C HD Si  (Read 7011 times)
Offline Ken L
  • Unit(s): 598C HD DI-SI
  • Software: 6.460
  • Accessories: none
« on: October 17, 2013, 03:02:34 PM »
Help! all of a sudden  I can't record. The message just says error. recording has stopped. Everything else works. I am able to read previous recordings but I get the same message with different cards.
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: Recording on a 598C HD Si
« Reply #1 on: October 17, 2013, 03:24:14 PM »
Is the SD-card writeable?  IE. Is it unlocked?
Is the SD-card full?
Does you unit have a 2nd SD slot to try?
If yes's to the above and still failing, I would re-format a SD-card, then test.
Offline Ken L
  • Software: 6.460
  • Accessories: none
« Reply #2 on: October 17, 2013, 05:51:48 PM »
I checked the card and the lock/unlock tab was about halfway between the two. Will check the unit again tomorrow. Thanks for the quick reply.
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: October 18, 2013, 11:44:20 AM »
You can check with it out of the water. Just turn it on and select record.
Offline Ken L
  • Software: 6.460
  • Accessories: none
« Reply #4 on: October 18, 2013, 03:12:38 PM »
Actually as I just found out all you need is a GPS fix and you can start recording. The lock tab was the problem. All is well. Thanks to all.
Last post August 28, 2009, 10:25:48 AM
by Rocketman783
recording
Started by stuart 798c SI
Last post January 19, 2010, 08:53:26 PM
Last post August 16, 2010, 09:05:44 AM
Last post August 22, 2010, 01:43:13 AM
by Sakai
Last post June 12, 2011, 12:13:42 AM
by T.G
Last post January 16, 2012, 02:04:02 AM
by rhayes2849
Last post April 18, 2012, 10:39:32 PM
Last post February 04, 2013, 04:10:50 PM
by Ken L
