Author Topic: poor 997 imageing  (Read 16840 times)
Offline mulliemark
poor 997 imageing
« on: September 16, 2013, 04:57:34 PM »
      I have 2 used 997's  and the imaging is just horrendous at low speeds  at any thing below 1 plus mph  everything is blurred and it is hard if not impossible to pick out detail. I use them on the bow and have tried them on 2 diff t/d's same results. I can look at my 798 running at the same time and the pic is way way better, any thoughts?
mark
Re: poor 997 imageing
« Reply #1 on: September 17, 2013, 02:16:13 PM »
What Chart Speed are you using?
Offline mulliemark
« Reply #2 on: September 17, 2013, 08:54:09 PM »
chart speed of 1 and these are the better ones
Offline LocDown
    • Fishing Videos
  • Unit(s): 1199 H12G2N-HW-MSI
« Reply #3 on: September 17, 2013, 10:56:43 PM »
Is the transducer mounted on the trolling motor? If yes, is the trolling motor pointing forward while scanning?
Offline mulliemark
« Reply #4 on: September 18, 2013, 09:29:25 AM »
yes and yes
« Reply #5 on: September 19, 2013, 08:34:30 AM »
For a speed of 0.3 and 0.8 mph that may be as good as it gets.  I'm not 100% sure on this as it has been a very long time since I have tried any Si imaging at these speeds.  I do know that you will have to keep a very straight track and constant speed at these slower speeds to get any sort of clear image.
Offline mulliemark
« Reply #6 on: September 19, 2013, 09:52:13 AM »
when your on the t/m these are the speeds you get. My 798 resolution  at these speeds is light yrs ahead of the 997
« Last Edit: September 19, 2013, 10:09:48 AM by mulliemark »
« Reply #7 on: September 19, 2013, 01:01:36 PM »
You mentioned 2 - 997's....
Are both 997 units using their own xducer...and both have this same problem...??
Have you tried either of the 997's on the 798 xducer...??
« Last Edit: September 19, 2013, 01:03:10 PM by rnvinc »
Offline LocDown
    • Fishing Videos
« Reply #8 on: September 19, 2013, 10:17:09 PM »
I tend to get better readings at 2-3mph at chart speed 1 at 455khz. I can't seem to get my 800khz scans to be as clear so I gave up on that freq.
Offline mulliemark
« Reply #9 on: September 19, 2013, 10:34:45 PM »
yes but thats not the speed you scan at on a t/m
Rn I only run a 997 at the bow and my 798 on the console  and when I am on the t/m I spin the 798 around  to compare images at sub 1mph
Offline LocDown
    • Fishing Videos
« Reply #10 on: September 19, 2013, 11:02:00 PM »
I've never been able to get very good scans going that slow. I always end up turning or something messing up the sidecan.
Offline mulliemark
« Reply #11 on: September 20, 2013, 12:02:36 AM »
I am talking about the part when you are traveling in a fairly straight line and the 997 can't pick out detail unless something is very close to being under the boat then it can pick out some fair detail
Offline LocDown
    • Fishing Videos
« Reply #12 on: September 20, 2013, 12:26:05 AM »
I wonder if your transducer for the 997 has deteriorated. Can you swap the 798 and 997 and see if the problem is the transducer.
Offline mulliemark
« Reply #13 on: September 21, 2013, 09:52:05 AM »
same result with  2 diff  ducers one of which is new
Offline LocDown
    • Fishing Videos
« Reply #14 on: September 30, 2013, 07:26:20 PM »
How about leaving the trolling motor in the water with the 997 on and using the outboard to maybe go 2-3mph and see if the scans look any better.
Offline silentkilla
  • Unit(s): 998c
  • Software: 6.610
« Reply #15 on: October 01, 2013, 08:37:12 PM »
I've always read that it's best to have SI on the Trans & DI on the TM! Works good that way for me.
Last post October 22, 2010, 11:12:52 PM
by Colt45
Last post April 03, 2011, 12:59:53 PM
by fishingho
Last post April 03, 2013, 12:46:53 PM
Last post May 22, 2013, 11:34:34 AM
Last post October 21, 2013, 10:35:12 AM
Last post May 12, 2014, 12:11:13 PM
by Ronny
Last post July 31, 2015, 03:02:21 PM
by Landry
Last post October 06, 2016, 08:40:33 PM
by 362 ranger pilot
