Author Topic: What cable to use for connecting 900/1100 series to a PC/laptop  (Read 24753 times)
Offline Peter
  • Golfe de Frejus - BYMS 22
    • Oxygen for Digital Diving
  • Unit(s): 1197c Si and Solix 16
  • Software: 4.750
  • Accessories: A boat !!!
« on: January 24, 2010, 11:29:59 AM »
Hi,
According to Humminbird's FAQ (http://www.humminbird.com/support/faq.aspx?faqid=34) the AS PC2 Accessory Kid is not recommended for any 900 or 1100 series product.
What should I use/order to connect my 1197c SI to a PC/laptop running HumminbirdPC?
Regards, Peter.
« Last Edit: January 24, 2010, 11:31:33 AM by Peter »
Offline keizerh
  • Unit(s): none
Re: What cable to use for connecting 900/1100 series to a PC/laptop
« Reply #1 on: January 24, 2010, 12:40:31 PM »
Cable is ok, but don't use battery's to power op your 1197
hendrik
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #2 on: January 24, 2010, 01:00:18 PM »
As Hendrik already mentioned. You'll be able to transfere the data from/to your unit, but the power supply cable from the cable set will not be sufficient to provide the neccessary power for the unit.
If you want to use it, cut the batterie connector off, place an in line fuse into the +wire and connect the improvised power cable either to a fully charged 12V batterie or you might also use a power converter like discussed here: http://forums.sideimagingsoft.com/index.php?topic=620.0
Regards / Harry
YES,......
WE SCAN!
Last post September 03, 2009, 07:42:41 PM
by Keith Councell
Last post April 15, 2010, 07:17:01 AM
by Louis
Last post August 17, 2011, 06:14:43 AM
by Angry
Last post September 03, 2012, 10:44:57 AM
by Jdeee
Last post April 08, 2013, 01:29:07 PM
by Warrior12934
Last post January 13, 2014, 11:56:14 AM
by knorstu
