Author Topic: Screenproblems on 1197 when connected to a 958  (Read 6644 times)
Offline guidoste
  • Unit(s): 898;998;1198
  • Software: 6.570
« on: August 01, 2013, 05:37:10 AM »
On the boat I have a Humminbird 1197 (used as master with SI Transducer and GPS) With Ethernet connected a Humminbird 958 (Sharing GPS from 1197 and for 2D also from 1197)
When 958 not connected, 2D on the 1197 works fine. When I connect the 958 then the pixels on the Humminbird 1197 (2D mode) becomes bigger. The SI still works fine. On the 958 it works fine.
Software on 1197 - 6.640
Software on 958 - 6.610
Any suggestions?
Offline JEVSkeeter
  • Unit(s): Onix 10 SI, Helix 12, 1199, 999, 360
  • Software: Current
Re: Screenproblems on 1197 when connected to a 958
« Reply #1 on: August 02, 2013, 10:37:19 AM »
Check your source on the 1197 and make sure you are not trying to use the 958's TD when it's connected.
Offline guidoste
  • Software: 6.570
« Reply #2 on: August 02, 2013, 10:41:24 AM »
Thank you for your reply. On the 958 is no transducer connected. The only transducer is on the 1197.
Last post March 03, 2011, 02:32:45 PM
Last post December 27, 2011, 12:23:24 PM
Last post June 03, 2012, 01:25:28 AM
by confusedfisherman
Last post June 05, 2012, 01:28:20 PM
Last post March 22, 2013, 05:59:11 AM
by chuckauten
Last post April 19, 2013, 12:06:28 PM
Last post March 07, 2014, 02:07:06 PM
Last post April 25, 2014, 06:52:47 PM
