Author Topic: Editing waypoints  (Read 10220 times)
Offline G4bama
  • Unit(s): 898c SI
Editing waypoints
« on: June 02, 2013, 06:12:56 PM »
So I can use this program to name and assign different Icons to my waypoints that I have saved on my 898 unit? I just need to export my waypoints to an SD card and look at them using this program? I know that this can be done on the unit itself but it is time consuming.
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: Editing waypoints
« Reply #1 on: June 03, 2013, 10:32:46 AM »
Yes.  IMO, using HBPC is much easier than all the key-punching required on the unit.
Hint:  To change a number of waypoint icons at the same time.
Select all the waypoints to change using Left-Click with Shift-key and/or Ctrl-key.
Then Right-click in the Icon column, select change icon, then pick icon.
Copy&paste, cut&paste functions are useful inside a GPX file or from GPX file to another GPX file.
Do not create duplicates within a GPX file.
« Last Edit: June 03, 2013, 11:00:43 AM by LittleGazoo »
Offline G4bama
  • Unit(s): 898c SI
« Reply #2 on: June 03, 2013, 07:04:12 PM »
I figured that, I just wanted to ask before hand to verify that you could do that type of editing. I just didn't want to download programs that didn't do what I needed because there seems to be a lot of problems with hummingbird software and upgrades. I haven't made up my mind if these software issues that people have are caused by user or programming errors.
Last post September 13, 2009, 11:39:21 AM
by Wall-E-Baiter
Last post November 12, 2014, 09:10:58 PM
Last post May 05, 2013, 04:02:51 PM
by matt@reefmaster
Last post January 08, 2014, 10:44:45 AM
by LittleGazoo
Last post September 30, 2015, 06:55:55 PM
by CamoHunter
Last post December 27, 2015, 11:49:26 AM
Last post April 29, 2017, 11:00:35 PM
by Conrad_Turbo
