Author Topic: ERROR: Incorrect checkbit35: at position 35  (Read 28081 times)
Offline promapper
  • Unit(s): 997C SI, 2-998C HD SI, 596C-HD-DI
  • Software: as of 5-08-13
  • Accessories: AS 360, I-Pilot Link, InterLink,Navionic
« on: May 09, 2013, 06:10:55 PM »
Every file I try to convert with the HBSI Converter returns this error.
ERROR: Incorrect checkbit35: at position 35Has anyone else seen this.
Running a 998 and 6.610 software
Windows 7
other converters will work but will not generate the proper format for Yellowfin
Re: ERROR: Incorrect checkbit35: at position 35
« Reply #1 on: May 10, 2013, 06:28:55 PM »
I will have this fixed this weekend.
Robert.
Offline promapper
« Reply #2 on: May 10, 2013, 08:06:19 PM »
you are super!  Thanks for looking into it!
JoeH
  • Guest
« Reply #3 on: December 23, 2013, 10:26:36 AM »
I have downloaded what I believe is the latest version of HBSI (1.1.0.1, Copyright 2013) and I am getting this message.  My unit is a 798CI HD SI COMBO.
The converted .872 file has 0 bytes..  Thanks for any insights.
Offline surveyor
  • Hydrographical Surveys
  • Unit(s): 1198C SI Combo
  • Software: 6.740
« Reply #4 on: March 21, 2014, 11:23:44 AM »
Dear RGacy,
Can you PLEASE check why this Error code below keeps popping up in HBSI Convertor?
ERROR: Incorrect CheckBit 35 at Position: 35
I run a Win7 64 Bit window version and a 1197 and 1198 data with older recorded files (old Firmware) and newest Firmware updates.
None helps.
When I run V 1.1.0.1. on a standard Win7 32 Bits 10.1 Inch laptop, it runs fine???
Can you help me or can I work arround that?
I already tried compatibillity with other Window Versions, yet none helps.
Kindest regards and thank you for your reply in advance,
Surveyor
Offline massillonbuckeye
  • Unit(s): Onix 8nt SI, 788, AC Pro, LM Great Lakes
  • Accessories: Terrova/I-Pilot Link
« Reply #5 on: October 08, 2014, 01:00:18 AM »
I'm still having this error.  Reinstalled a few times now.  My version reads 1.1.0.1.  Its what I download from the downloads section.
Offline abraquelebout
« Reply #6 on: October 08, 2014, 12:07:32 PM »
hi
same thing with new upgrade in 1198
my old 898 is no upgraded, no problem.
i think new version of firmware in unit make this....
Offline tambrose76
  • USMC Ret.
  • Unit(s): 898c, 737, WIDE ONE, SUPERTRAP30, PORTAB
  • Software: ALWAYS UPDATED
  • Accessories: GPS16 WXSENSE
« Reply #7 on: September 04, 2015, 02:14:24 PM »
4Sep2015... same issue. did this ever get fixed?
"Some men see things as they are and say why.
I dream things that never were and say why not." --George Bernard Shaw
« Reply #8 on: September 05, 2015, 06:02:58 AM »
No it's not fixed, if you want to use deepviewer, convert .dat in xtf with son2xtf and open it in deep. it's working.
waiting for next hbsi sonar data file converter.
Offline muskyhntr
  • Unit(s): Helix 8 MegaSI
« Reply #9 on: October 25, 2021, 08:39:49 PM »
Is there any way to work around this error and get the HBSI Sonar File Converter to work? I am trying to convert HB.DAT file to .DVS to view with Deep Vision app.
Thanks!
Offline Rüdiger
« Reply #10 on: October 26, 2021, 02:33:57 AM »
Hi muskyhntr
Welcome to the forum
As abraquelebout writes, convert .son to .xtf with the help of son2xtf, which Deep Vision can read.
http://forums.sideimagingsoft.com/index....sa=view;down=26
mvh
Rudiger
Finding is better than losing
Offline muskyhntr
« Reply #11 on: October 26, 2021, 07:17:10 AM »
Rudiger, thank for the quick reply! I have been trying to find the Son2xtf file with no success. Unfortunately, I got an error 404, file not found message on the link you provided. All help is greatly appreciated.
Muskyhntr
Offline Rüdiger
« Reply #12 on: October 27, 2021, 02:52:37 AM »
Offline muskyhntr
« Reply #13 on: October 27, 2021, 09:12:18 PM »
Son2XTF must be the most elusive application on the web! I tried the link, but I got a message that .NET framework 1.1 needed to be downloaded. I'm using Windows 10 with .NET 4.8. .Net framework 1.1 is no longer supported or available from the .NET site.  :'(
Any help appreciated.
Muskyhntr
Offline Rüdiger
« Reply #14 on: October 28, 2021, 02:48:30 AM »
Hi Muskyhntr
I need your email address.
mvh
Rüdiger
Offline muskyhntr
« Reply #15 on: November 05, 2021, 08:08:42 PM »
PM sent. Thanks.
Offline tournevase
  • ARCHAEOLOGICAL SURVEY
    • GRAS
  • Unit(s): HELIX 10 G4N CHIRP MEGA SI +
  • Software: AUTOCHART PRO
« Reply #16 on: January 13, 2022, 05:17:21 PM »
hello all
i want to use yellowfin
the only one converter is HBSI gives yet "ERROR: Incorrect CheckBit 35 at Position: 35" and issue  empty .872 files  :'(
is there an improvment ?
Tournevase
Offline Rüdiger
« Reply #17 on: January 14, 2022, 03:37:55 AM »
Hi Tournevase
Which converter do you want to install?
mvh
Rüdiger
Offline tournevase
    • GRAS
« Reply #18 on: January 14, 2022, 08:11:58 AM »
i used "HBSI file sonar converter" to convert hummin files to .872 because yellowfin use .872
when i launch the conversion i get "ERROR: Incorrect CheckBit 35 at Position: 35" and an empty .872 file is created
then impossible to use yellowfin
Tournevase
Offline Rüdiger
« Reply #19 on: January 15, 2022, 03:54:32 AM »
Hi Tournevase
Try DeepView https://deepvision.se/download/sonar-software/ and the Son2xtf converter  http://forums.sideimagingsoft.com/index.php?action=downloads;sa=view;down=26 , works with win 10.
mvh
Rüdiger
Offline tournevase
    • GRAS
« Reply #20 on: January 24, 2022, 11:45:26 AM »
hi rûdiger
i  used deepview fv
the display at screen has a good accuracy
my aim is to get pictures in png or jpg for publications with the best accuracy
by using deepview fv the way is : convert .dat of the hummibird to  xtf -> dvfv generate a pdf -> i convert the pdf in image format
i'am not sure that it gives the best image
finally the qustion is how to get an image  with the resolution of the ra
Tournevase
Offline tournevase
    • GRAS
« Reply #21 on: January 24, 2022, 11:47:15 AM »
sorry
finally the question is how to get an image  with the resolution of the raw original file ? 1 px = 1 sampling pitch
Tournevase
Offline Rüdiger
« Reply #22 on: January 26, 2022, 03:39:46 AM »
Hi Tournevase
I've never done that myself, so I can't help you there. Maybe there is another user here in the forum who can help you.
mvh
Rüdiger
Last post August 05, 2009, 09:34:43 AM
Last post December 23, 2010, 09:23:09 AM
Last post March 27, 2011, 03:46:51 PM
by KickSomeBass
Last post February 03, 2012, 04:26:18 PM
Last post February 15, 2012, 11:28:03 AM
Last post April 11, 2012, 08:49:42 AM
Last post May 14, 2013, 05:50:23 PM
Last post April 06, 2015, 04:25:04 PM
by steelebob
