Author Topic: New to me 997c  (Read 8080 times)
Offline 4d-rock
  • Unit(s): 997c SI, 778c, 570
  • Software: 6.30
New to me 997c
« on: April 30, 2013, 12:12:54 PM »
Hey Guys,
I just received in the mail my second hand 997c SI.  I am very stoked to have this because I had a budget of max $600 and if I wouldn't have found this, I wouldn't have had the money to get a SI unit.
I do have some questions for the vast knowledge of these forums.
I am looking into installing the unit on my console, however the dash seems to be made of a thin fiberglass.  Should I be reinforcing the underside, and with what?
I'm thinking about getting a RAM mount, mainly because the spot on the dash isn't big enough for this beast.  I'm attaching a picture of the console, and you can see that i'll be putting it in the place where that old Lowrance X47 is sitting.  So I'm looking into a swing arm model (RAM-109HU), does anyone use this model with a 997c or similar unit?  Are the holes on the bracket correct for the 997c?
http://www.gpscity.ca/ram-mount-horizontal-bent-swing-arm-with-2x6.25-inch-post-plate.html
The unit has Version 4.95 installed onto it.  Is it worth it to upgrade to 6.3?  I've read the list of changes for the versions, but not having used it before I don't know how beneficial it would be.  Especially with some of the stories of people's units crapping out on them after upgrading.
Lastly, a minor thing.  But in the system information screen it logs how many hours are on the unit.  I know with motors and mechanical things the number of hours makes a difference, but is this something to be worried about?  Mine came used with 860 hours, so it has seen it's fair share of time on the water.  Is there an average expected hour lifespan of these units before it self-destructs? (sorta joking)
Once I start the installation process I may pop back in here for advice on transducer placement, though I think I have a good idea from many of the posts I've been reading here.
Re: New to me 997c
« Reply #1 on: April 30, 2013, 04:06:54 PM »
Usually with electronics, if you make it past the first four hours of operation they should work for a very long time without failing.  I’ve got a 987 with over 700+ hours on it and a 998 with 1,000+ hours on them and they both still work.
Offline 4d-rock
  • Software: 6.30
Re: New to me 997c
« Reply #2 on: April 30, 2013, 06:01:46 PM »
Thanks Greg.  I figured that would be the case, just thought I'd ask.
Anyone have any ideas on the mount or the update?
Offline eddieproctor
  • Unit(s): 597 HD 788 ci 997 c
  • Software: 6.30
  • Accessories: interlink
Re: New to me 997c
« Reply #3 on: July 03, 2013, 11:33:59 AM »
Yes go with the ram mount!! as for hours my 997 now has 2164 hours on it and still going Strong!!!
Offline 4d-rock
  • Software: 6.30
Re: New to me 997c
« Reply #4 on: July 03, 2013, 11:36:26 AM »
Nice!
Ya I did end up going with the RAM-111U mount.  Works very well and loving my 997c.  Gotta play around with the map making next.
Last post April 09, 2014, 06:22:56 PM
Last post January 31, 2015, 11:12:37 AM
Last post August 18, 2015, 02:31:01 AM
Last post November 24, 2015, 02:00:29 PM
Last post January 04, 2016, 11:23:27 PM
by 49thdiver
Last post September 17, 2017, 06:04:58 PM
Last post May 05, 2019, 09:40:56 PM
by Delta Bass Fool
Last post April 14, 2023, 06:44:50 PM
by DiveExplorer
