Author Topic: 898 SI thoughts on photo  (Read 13575 times)
Offline Lsobo21
  • Unit(s): Helix 10 G1 and G3
« on: April 27, 2013, 08:27:27 PM »
I am looking for any thoughts on what is causing the line or cloudiness on the LH side water column?  I can see structure so I don't think it is the motor.  Any thoughts?
1775 Impact w/ 115 4-stroke
Helix 10 G3 on the console, Helix 10 G1 on bow
Offline Jdeee
  • Unit(s): 1198
  • Software: 6.10
  • Accessories: External gps HS
Re: 898 SI thoughts on photo
« Reply #1 on: April 28, 2013, 08:29:03 AM »
There seems to be a stronger interference on the bottom ( older ) readings and then it looks to be starting to get less/lighter, which leads me to believe that it's the motor as you slowed down.
Try shutting off the motor and coasting to see if it goes away and that will tell you if it's the motor.
If that is not the case it could be some sort of turbulence caused by the boat which would also do the same thing as you slowed down.
You might want to include more info on your setup and maybe a photo or two.
« Last Edit: April 28, 2013, 08:32:57 AM by Jdeee »
Offline Lsobo21
« Reply #2 on: April 28, 2013, 09:15:04 AM »
Thanks for the input...attached is the install, maybe I am getting bubbles from the rivets...it's one sensor so that sort of confuses me why one side would do it,but i don't know how it actually works in that sensor.
Thank you again...maybe I can lower it some more.
« Reply #3 on: April 28, 2013, 10:32:06 AM »
Is the motor "trimmed up" out of the way when this happens...??
Set the SI range to 10 ft and see if the distance from the SI centerline to the "cloudiness" indicates the same distance from the xducer to the motor itself...
Offline Lsobo21
« Reply #4 on: April 28, 2013, 11:44:52 AM »
yep, when the motor is out all the way it happens too, but it seems to decrease when speed is below one...Someone mentioned that maybe the screen on the livewell intake may be an issue as well.  Ill take it off and see.
« Reply #5 on: April 29, 2013, 02:18:25 PM »
If this is speed related than it should go away completely when the motor is off, trimmed all the way up and the boat is drifting.  If it is still there than it could be the livewell intake screen or something else sticking out from the transom of the boat or we have even seen where the transducer itself can cause this.
Offline Lsobo21
« Reply #6 on: April 29, 2013, 06:26:46 PM »
Not the screen I took it all the way off with no change.  I raised it up some more to try to get better high speed, which I did...about 32-35 mph before it went nuts depth wise.   I am guessing it is air bubbles....however I have seen other people's photos with that same Cloud on the same side.
« Reply #7 on: April 30, 2013, 01:20:07 AM »
Greg's advice of checking while drifting will indicate if the lines are caused by bubbles of the hull...not moving = no bubbles...:
If lines disappear when drifting...it is bubbles from the hull...
If lines are still present when drifting...there is a blockage....
You can temporarily mount the xducer to a broom stick and stick it down in the water to verify if there is any problem with the xducer itself...
Typically (in most cases) these types of lines showing next to the center line on the left side is bubbles or blockage..
« Last Edit: April 30, 2013, 01:24:38 AM by rnvinc »
Offline tgordon
  • Unit(s): 898c HD SI Combo, 788ci HD DI
« Reply #8 on: July 04, 2013, 11:38:15 AM »
I have the same issue. I think mine is the rib a few inches from the ducer on the left side of my aluminum Bass Tracker. I'm going to move mine over to the right and see what happens. I'll post info afterwards.
TG.
Terry Gordon
Salvisa, KY
Offline seamonkey
  • Unit(s): 898si
« Reply #9 on: July 04, 2013, 01:51:29 PM »
I had the same issue .   Mine would do it while just sitting on the trailer. I updated my firmware to 6.640 and it went away.
Offline Southbound
  • Unit(s): 898C SI
  • Accessories: non
« Reply #10 on: July 10, 2013, 01:00:11 PM »
 Could it be the  Thermocline layers in the water?
« Reply #11 on: July 11, 2013, 10:03:48 AM »
If it were a thermocline layer than it would show up in both the left and right Si sonar.
Last post January 14, 2013, 08:33:07 PM
by cachristian
Last post August 16, 2012, 03:44:22 AM
by river life
Last post September 06, 2012, 03:01:45 PM
by Kimi
Last post May 27, 2013, 10:05:09 PM
by promapper
Last post July 11, 2013, 02:15:36 PM
by rockfishbuster
Last post March 02, 2014, 05:29:54 PM
Last post August 25, 2014, 09:37:50 PM
by reelhandy
Last post January 07, 2016, 02:19:15 AM
by 49thdiver
