Author Topic: New 598 si no right side  (Read 6044 times)
Offline Ken L
  • Unit(s): 598C HD DI-SI
  • Software: 6.460
  • Accessories: none
« on: April 10, 2013, 04:23:08 PM »
I can't say the left side is at all like some of the images I see here but that could be because of my own inexperience. The transducer is mounted on the right side of my kayak so the right side of the transducer has a clear view. On the green palette I get featureless pea soup. I have covered the same shore line in both directions and the result from the right side is the same.  Bad transducer?
I would also like to know what settings you all use to get those images. I have a trolling motor mounted on the back so a steady 2 mph is easily had.
Thanks in advance.
Re: New 598 si no right side
« Reply #1 on: April 10, 2013, 04:35:49 PM »
Sounds like a bad transducer or it could be something in the unit (less likely).  Know anyone else with a Humminbird Side Imaging unit (any model) that would let you test your unit on their boat?
Offline Ken L
  • Software: 6.460
  • Accessories: none
« Reply #2 on: April 11, 2013, 01:04:58 PM »
I am the early adopter in my group so I know of no one with a compatible unit. I will call Humminbird.
Last post July 23, 2010, 05:18:21 PM
Last post October 17, 2012, 01:37:25 PM
Last post May 22, 2013, 11:34:34 AM
Last post October 02, 2019, 11:10:51 AM
Last post June 24, 2016, 11:52:54 PM
by snooktarpon
