Author Topic: Version 81 of HumViewer release  (Read 30339 times)
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
  • Accessories: Speed sensor
« on: April 08, 2013, 04:50:41 PM »
Hi
I have just released a new version of the HumViewer program. It can be downloaded from http://humviewer.cm-johansen.dk/
Change Log
Version 81 (Release date 08-04-13 21:28)
-Added support for recordings made with new Humminbird firmware 6.600
-Added possibility to hide GPS position data when making movies and snapshots
-Added support for showing boat position dynamically in google earth when scrolling in HumViewer
-Changed the way google earth is opened, so it is no longer required to know installation directory
-Changed directory handling so it can now run on MAC (will be available soon)
« Last Edit: April 08, 2013, 04:53:23 PM by RGecy »
Offline keizerh
  • Unit(s): none
Re: Version 81 of HumViewer release
« Reply #1 on: April 08, 2013, 05:04:03 PM »
Hi Martin,
How are you?
Great to have you back.
Pity your pm box is full, so I can't reach you in person.
Could you please send me a mail to hjkeizer@planet.nl?
Offline Trytoofish
  • Software: 2.0, 7.51,
« Reply #2 on: April 08, 2013, 05:12:50 PM »
Hi Martin
 Thanks for the update. Question. Will this work on a 64 bit windows 7 platform? Thanks
Try Too Fish  Forced To Work
« Reply #3 on: April 08, 2013, 05:32:45 PM »
It's good to hear you're still with us Martin...
Thanks for your continued work...
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #4 on: April 08, 2013, 05:42:58 PM »
Hi Martin
Don't know if it will work on 64-bit, but it is working on Windows 7 32-bit.
Offline Kim Christiansen
  • Kim Christiansen
    • Danas Have Denmark
  • Unit(s): 798ci SI HD Combo
  • Software: 6.250
« Reply #5 on: April 08, 2013, 06:11:09 PM »
 :) Hello mrj9600
Thanks for the update, you will make many people happy here in this forum!
Sincerely,
Kim Christiansen
above the clouds the sun always shines !!!
Offline strawdg
« Reply #6 on: April 08, 2013, 07:54:29 PM »
I see many others saying the same thing......
Thank you..... Your work is appreciated more than we can express..... and there isn't a smiley on this site that expresses that enough.....
Straw
Offline Perch Jerker
  • Unit(s): 1198
  • Software: 6.490
  • Accessories: transducer select switch
« Reply #7 on: April 08, 2013, 08:57:05 PM »
Many, Many thanks Martin for this update, I have been waiting and hoping for this. Now I can update my unit.Thanks again RAY.
« Reply #8 on: April 08, 2013, 10:18:25 PM »
Will this new updated version work with both the old and new Humminbird software revision recordings?
+ another thank you for keeping this valuable software updated.
Offline depark1
  • Unit(s): 998CX SI
  • Software: 6.180
« Reply #9 on: April 08, 2013, 11:44:39 PM »
Hi Martin
Well I just installed the new version on my Windows 7 Ultimate 64  bit machine and I am happy to report that it is working fine.  I tried a couple of my recordings and all is well.  Great Job Martin!!!!!
Cheers
Darryl
Offline newkid4si
  • Unit(s): 998c si
  • Software: v 5.70
« Reply #10 on: April 09, 2013, 12:09:10 AM »
mrj9600
   Thank you for a very valuable resource to many of us.
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #11 on: April 09, 2013, 01:57:29 AM »
Yes, this version should work for both old and new recordings.
Offline Rüdiger
« Reply #12 on: April 09, 2013, 03:20:34 AM »
Thank you Martin
This saves us the futile wait, the HB presents its own software.  :(
mvh
Rüdiger
Finding is better than losing
Offline didier74
  • Unit(s): 1197 cx SI/1198 cx SI
  • Software: 6.310/6.490
  • Accessories: Ethernet switch
« Reply #13 on: April 09, 2013, 12:15:34 PM »
All thanks,
From french user..
Offline Moose1am
  • Unit(s): 898c si
  • Software: 6.610
« Reply #14 on: April 09, 2013, 06:11:18 PM »
Thank you.  I love hummviewer.  I see things using this program on my computer that I would never see just looking at the humminbird monitor on my boat.
Regards,
Moose1am
Offline Jolly Roger
  • HB Addicted
  • Software: latest (mostly)
« Reply #15 on: April 09, 2013, 06:22:53 PM »
Hi Martin,
and thanks a lot for your work!
If I try to start Hummviewer, a window shows up stating: "Could not creat the Java virtual mashine".
Any idea how I can get Hummviewer working?
Regards/Harry
YES,......
WE SCAN!
Offline LittleGazoo
  • Software: 3.640
« Reply #16 on: April 09, 2013, 08:46:50 PM »
Thanks for updating.
I am having problem with Googleearth connection, cause GE does not get started.
I'm on Windows 7 64-bit with Java 1.7.0_17.
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #17 on: April 10, 2013, 01:41:03 AM »
Hi Martin,
Regards/Harry
Hi Harry
Did HumViewer work before the updating ?
Do you install with java/jre bundled or only program ?
Anyone else having problems running HV after install ?
Best regards
Martin
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #18 on: April 10, 2013, 01:43:54 AM »
Do you know if GE is set up as default program for *.kml files ? You can check it by finding a file the .kml extension and double click it. If GE is default program is should start up and show the file.
Offline Jolly Roger
  • HB Addicted
« Reply #19 on: April 10, 2013, 08:17:46 AM »
Hi Harry
Best regards
Martin
Yes Martin,
Hummviewer was running before I updated. I tried both versions of download. The bundle version as well as the program only version. I also downloaded the latest Java version from the website you mentioned.
Another odd thing: Is the older version ereased when I download the 81 version? I cannot find it my software register any more.
Best regards/Harry
YES,......
WE SCAN!
Offline mrj9600
    • Home of HumViewer
  • Unit(s): 997C SI
  • Software: 6.300
« Reply #20 on: April 10, 2013, 09:41:29 AM »
Yes Martin,
Best regards/Harry
Yes the older version is overwritten, but I think I will make the old version available from my webside. I will do that tonight. Then I would like you to download the old version again and see if that works.
Also in the meanwhile. Can I ask you to try and download version 86, and try if that works.
« Last Edit: April 10, 2013, 09:48:51 AM by mrj9600 »
Offline Jolly Roger
  • HB Addicted
« Reply #21 on: April 24, 2013, 02:29:51 PM »
Hi Martin,
86 didn't work. Can you check the links of the older version on your website? If I click on them, they wont work.
Regards/Harry
YES,......
WE SCAN!
Last post February 05, 2010, 04:46:14 AM
by mrj9600
Last post June 06, 2010, 10:49:18 AM
by pascalfromfrance
Last post February 26, 2010, 10:33:54 AM
by stillbear
Last post June 16, 2010, 03:16:50 PM
Last post October 31, 2011, 03:55:49 PM
Last post April 08, 2013, 05:30:52 PM
Last post April 18, 2013, 10:46:47 PM
by Jay415
Last post May 05, 2015, 09:54:10 AM
by FlyFisher SLC
