Author Topic: New software 6.610  (Read 16192 times)
Offline navionic
New software 6.610
« on: March 16, 2013, 03:20:03 PM »
788ci HD, 788ci HD DI, 798ci HD SI, 898c SI, 998c SI, 1198c SI
v6.610 includes changes to POS Script Updates and includes general performance and stability updates plus everything included in v6.600 • Added enhancements for 2D/DI/SI sonar scroll rate on the 798ci HD SI. • Fixed an issue where SI data was scrolling at twice the intended rate. • Fixed an issue where 2D/DI data was not in sync on the 798ci HD SI. • Fixed an issue where 2D/DI data was not in sync if 83/200 kHz mode was enabled. • Fixed an issue where DI Zoom was not in sync. • Fixed SI Sensitivity issues on the 898c SI, 998c SI, 1197c SI, 1198c SI. • Fixed an issue where Demonstration Mode OFF would not force normal mode and a connected transducer state. • Fixed an issue where rapidly forcing the unit into Simulator Mode could cause the unit to restart. • Fixed an issue where Ethernet sonar subscriptions would eventually drop off if the Control Head was booted with Sonar turned Off • Fixed an issue where Ethernet sonar subscriptions would eventually drop off if Sonar was turned Off and then back On within 60 seconds without a reboot. • Fixed an Ethernet issue where the Heading Line ON/OFF setting would not be saved between restarts while subscribed to a remote AS GPS + HS. • Removed Universal Sonar II transducer selection option, now users should select dual beam as their selection. • LakeMaster map coding was updated to work with i-PilotLINK • Tweaks were made to radar functionality to fix a memory leak • Fixed a bug that caused some models to sometimes skip a view when cycling through views. • Locked NMEA output at 4800 baud when enabled • Added 360 Imaging operation menus and capabilities • Added iPilotLINK operation menus and capabilities
Offline LittleGazoo
  • Software: 3.640
  • Accessories: Ethernet
Re: New software 6.610
« Reply #1 on: March 16, 2013, 03:43:08 PM »
So in a nutshell, it is 6.600 + Added iPilotLINK operation menus and capabilities.
Offline navionic
« Reply #2 on: March 16, 2013, 05:09:11 PM »
iPilotLINK already been added to 6.600
This version soon eliminate gaps 6.600
Offline Trytoofish
  • Software: 2.0, 7.51,
« Reply #3 on: March 16, 2013, 05:16:55 PM »
I just checked my account. my 998 still shows 6.6, anyone showing 6.61 for a 998 yet? My 798 shows 6.61 released 3/15/2013, but not so for the 998
Try Too Fish  Forced To Work
« Reply #4 on: March 16, 2013, 08:59:55 PM »
No, dont see 998c update yet. Still 6.600.
I see the 1198, 1997, and 898 have the 6.610.
Offline wolfs4evr
« Reply #5 on: March 16, 2013, 10:12:42 PM »
Update went smooth on my 798/898 but unfortunately going to be several weeks before I am on the water again.
Offline TroyBoy30
  • Unit(s): 1198
« Reply #6 on: March 18, 2013, 08:43:08 AM »
no, its 6.600 plus changes to POS Script Updates and includes general performance and stability updates
Offline navionic
« Reply #7 on: March 18, 2013, 08:49:04 AM »
That's right.
Offline Gator
    • Crappie Club Page
  • Unit(s): 1198 c si, (2)998c si, 798ci HD si
  • Software: top secret
  • Accessories: ethernet, weather sence, I Pilot Link
« Reply #8 on: March 18, 2013, 09:09:38 AM »
X2... mine show the same
Offline Gator
    • Crappie Club Page
« Reply #9 on: April 02, 2013, 01:13:14 PM »
6.610 is now avaaliable for 998... git er done!!! ;D
Last post August 12, 2013, 12:15:35 PM
by RuffWood
Last post August 31, 2013, 11:00:33 AM
by Ken L
Last post January 07, 2014, 08:23:04 AM
by ALOTANOTA
Last post April 02, 2014, 03:35:56 PM
by Bowhunter1
Last post July 28, 2014, 06:19:28 PM
by zdriver
Last post September 09, 2014, 02:30:01 PM
by snuffer
Last post July 20, 2022, 08:24:25 PM
Last post September 05, 2024, 09:52:07 AM
by jimf
