Author Topic: 998 GPS  (Read 6038 times)
Offline arkie12003
  • Unit(s): 998c
998 GPS
« on: March 10, 2013, 01:27:12 AM »
I set a waypoint on the GPS and tried to return to it, track was on, and I did not use the cursor waypoint feature. It was very difficult to get back over the way point because the GPS update rate was to slow. I have had this problem with other GPS units does the cursor over waypoint feature have a faster update? I didn't try this I should have.
Offline Rüdiger
Re: 998 GPS
« Reply #1 on: March 10, 2013, 05:24:21 AM »
Hi Arkie
Yes, that's normal, because GPS is too slow. Therefore I use a compass to respond more quickly to course deviations.
The WP control using GPS, compass heading noted further steer with compass.
mvh
Rüdiger
Finding is better than losing
Re: 998 GPS
« Reply #2 on: March 12, 2013, 11:34:30 AM »
Arkie,
How is your GPS connected to your 998c Si unit?  A direct connection is best.
What software version are you running in your 998c Si unit?
GPS does not know what direction you are moving until it can compare where you were at the last reading versus where you are now.  This combined with the inaccuracy of the GPS system we are allowed to us makes slow speed direction and speed readings hard to accurately calculate.
We do have a new GPS Receiver that has a built-in compass: AS-GPS-HS.  It will always know what direction the boat is heading, even at slow speeds, and make getting back to waypoints even easier.
Offline zwhits
  • Unit(s): 998 HD, 778c
Re: 998 GPS
« Reply #3 on: March 17, 2013, 11:53:31 PM »
Is that the antenna that comes with the 998HD or would that be seprate?
Re: 998 GPS
« Reply #4 on: March 19, 2013, 10:38:24 AM »
The AS-GPS-HS is a separate accessory and is not currently packaged with any unit.
Re: 998 GPS
« Reply #5 on: March 22, 2013, 01:25:23 AM »
It is my opinion that the new AS GPS HS antenna is the "berries" for slow speed GPS operation...
http://forums.sideimagingsoft.com/index.php?topic=5109.0
Re: 998 GPS
« Reply #6 on: March 22, 2013, 03:38:39 PM »
Hmmm, what type of "berries" are you talking about here?  ;D
Re: 998 GPS
« Reply #7 on: March 23, 2013, 12:17:50 AM »
Do you remember from "Willy Wonka and the Chocolate Factory"...??
"The snozzberries taste like snozzberries"...
Anyway....HB done good with this AS GPS HS antenna ...it is awesome for slow speed GPS operation...
