Author Topic: Optional transducer spacer  (Read 6440 times)
Offline KeggER420
  • Unit(s): 798ci SI HD
  • Software: 6.250
« on: March 06, 2013, 05:15:46 PM »
In my new transducer mounting kit, HB has included an optional transducer spacer.  What is the purpose of this?
Pros?
Cons?
Thanks!
Re: Optional transducer spacer
« Reply #1 on: March 07, 2013, 08:41:13 AM »
Is this what you are talking about (see pic below)?
If so, this is used to plug the whole between the transducer and the pivot arm.  Some have to install the transducer lower in the water than what it was designed for and this plug blocks the flow of water through here as it can sometimes end up causing a roostertail of water to shoot up from the transducer.  Install it if you need it, otherwise don’t.
Offline KeggER420
  • Software: 6.250
« Reply #2 on: March 07, 2013, 08:43:13 AM »
Yep that's it! I wasn't sure if it helped prevent turbulence and air bubbles around the ducer
Thanks!
by Sonshine Fishing
Last post August 09, 2011, 04:37:57 PM
Last post November 25, 2011, 10:59:12 AM
by Brian37075
by jgcox6
Last post May 05, 2014, 11:31:11 AM
Last post August 18, 2016, 01:03:44 AM
by mako9man2
