Author Topic: GPS coordinate converting 1198SI  (Read 10550 times)
Offline boykinsbuddy
  • Unit(s): 1198
« on: February 20, 2013, 06:50:58 PM »
My 1198 is having issues and so am I. I need it for 2 more weeks for work before sending it in because it locks up frequently between changing views and dropping views. It seems to do this when I have any card in the slots while booting up. I have to go into the menus and reset to default and make sure all views are visible just to get a map to load.
Anyhow...somewhere in the menus there is a way to change the GPS coordinates from decimals to minutes and seconds, etc...I did it this morning...but darned if I couldn't find the offering this evening and don't know where to look on the manual. Help!
Re: GPS coordinate converting 1198SI
« Reply #1 on: February 20, 2013, 06:55:33 PM »
In the Setup Menu tab you will need to make sure the User Mode is set to advanced.  When you reset it probably went back to normal.
You should be able to see the Position format then.
Last post August 15, 2011, 04:48:37 AM
by Rüdiger
Last post January 20, 2012, 12:29:39 PM
Last post April 10, 2013, 05:00:02 PM
by easysailor
Last post May 01, 2013, 10:25:56 AM
by matt@reefmaster
Last post August 30, 2013, 09:26:36 AM
by SonarGene
Last post September 09, 2013, 06:28:54 PM
by RuffWood
Last post January 22, 2016, 05:23:21 AM
by buell1965
Last post May 01, 2018, 03:32:51 AM
by asifri
