Author Topic: using HUMMIMBIRD to see sub botton profile (goldming)  (Read 8922 times)
Offline riqson
« on: January 30, 2013, 07:48:14 AM »
Hey All !
I am looking for advises and indication for with one Hummimbird fishfinder more simple posivel I can read layers in sub botton of one river ?
with model? with the best transducer?how deep in the sub botton possible to read?color scale / grey scale?
I need to use as tool in gold mining prospect in river  ,
thanks in advance
riqson
Brasil
Offline tschultz
Re: using HUMMIMBIRD to see sub botton profile (goldming)
« Reply #1 on: February 02, 2013, 12:13:34 PM »
The Hbird unit is not a sub bottom profiler.  You need a sub bottom profiler for that.  You can get an idea of what the surface of the bottom is though.  Soft to hard.  Any Hbird unit will do that from the 385 to the 1198.
Offline Rickard
« Reply #2 on: February 02, 2013, 06:35:35 PM »
Hi,
I don't know much about bottom conditions in your area, but I can get profiles in glacial clay down to 10 meters using the 50 kHz channel. The transducer can't paint a detailed profile because of the large width of the beam. For better detail a large transducer element, or a Mills cross is needed. Then it should be possible to do sub-bottom profiling in not too hard seabeds.
Rickard
Offline Rüdiger
« Reply #3 on: February 03, 2013, 03:48:32 AM »
Hi Rickson
True sub bottom profiler operating at very low frequencies, but are also very expensive.
As Rickard already writing is not to make hard surfaces with 50kHz to quite a bit.
The transducer XHS9SI160T with 262/200/50 kHz of HB but can not even use only with the units 981c SI and 987C Si  >:(
AIRMAR has some alternative transducer for HB.
http://www.airmartechnology.com/2009/marine/product-search-results.asp
mvh
Rüdiger
Finding is better than losing
« Reply #4 on: February 04, 2013, 11:01:18 AM »
Rudiger, the XHS-9-Si-160-T transducer can be used by other 800/900 and 1100 series Side Imaging units.  Just select the “Sidescan” menu option in the Transducer Select/Connected Transducer menu.  You could also select the “Dual 50 / 200” menu setting if all you were going to use is the 2D sonar.
Offline Rüdiger
« Reply #5 on: February 05, 2013, 03:21:52 AM »
Hi Greg
The HB website says something else.
http://store.humminbird.com/products/313990/XHS_9_SI_160_T
XHS 9 SI 160 TTransducers.Transom Mount Transducer
"Side Imaging with built-in temperature. 262/200/50 kHz. Operates only with the 981C SI and 987C SI. Will not work with any other models."
mvh
Rüdiger
« Reply #6 on: February 05, 2013, 11:56:07 AM »
I’ve asked that this be changed Rudiger.  It should state something like: “Will not work with all Side imaging model units.  Consult your operations manual or contact the Humminbird Customer Resource Center before purchasing.”
Last post February 12, 2010, 12:46:48 PM
Last post February 28, 2010, 03:44:53 PM
Last post March 04, 2010, 06:15:45 PM
Last post March 07, 2012, 06:24:00 PM
by stillbear
Last post September 12, 2012, 07:12:50 PM
Last post September 21, 2013, 05:57:36 PM
Last post June 08, 2014, 05:00:15 AM
by j2000
Last post June 09, 2014, 03:15:24 PM
