Author Topic: COG  (Read 3350 times)
Offline Sigler
  • Unit(s): 1198c 788ci di
  • Accessories: interlink
COG
« on: November 07, 2012, 09:08:28 PM »
  On a new 998 COG appears on the side readouts, how do I get rid of it? Is there a way to turn it of?
Re: COG
« Reply #1 on: November 08, 2012, 09:12:11 AM »
That depends on which unit you are talking about, the software version in it and – more importantly – which View you are using and whether you are using the GOTO function or not.  You can go into the Select readouts menu and set that digital readout location to display something else (or nothing).  If it is not showing as being selected in the Select Readouts menu, than it is being displayed by default according to the View you are using and if you are using the GOTO function (travelling to a waypoint).  If this is the case than it could only be changed by a change to the unit’s software.
Offline Sigler
Re: COG
« Reply #2 on: November 09, 2012, 06:15:54 AM »
Have not hit GOTO it appeared on the graph when we got done installing it. I would say its the software and it comes up on all the navigation views.
