Author Topic: humminbird 998cx  (Read 8256 times)
Offline andre
humminbird 998cx
« on: October 31, 2012, 11:45:16 AM »
good evening I had a problem with humminbird 998cx , bad contact to the button a food, turns on the device, but doesn't switch off, includes illumination that doesn't switch off the device :'(
Re: humminbird 998cx
« Reply #1 on: October 31, 2012, 03:52:25 PM »
Try unplugging all cables to the 998cX Si unit and connecting up only the power cable; try powering it on then off again.
Be sure to check the electrical wiring all the way from the unit to the battery.  I recommend using at least a 14 AWG multi-stranded marine-grade copper wire and the blade type fuse and fuse holder.  Make sure all connections are soldered and sealed against moisture.  Also have your battery load tested to make sure that it can supply the needed amperage for the 998cX Si unit.
Offline andre
« Reply #2 on: November 01, 2012, 12:11:10 PM »
hello with conducting the button in the sonic depth finder (marriage of the button of a food) everything is all right jams
Offline andre
« Reply #3 on: November 01, 2012, 12:17:04 PM »
it is marriage of the button of a food of the sonic depth finder
« Reply #4 on: November 01, 2012, 01:13:10 PM »
My apologies, but I am not understanding your response andre.  ???
Offline andre
« Reply #5 on: November 01, 2012, 01:35:19 PM »
matter is not in wires it is power button. Button dont turn off the deep fish finder
« Reply #6 on: November 01, 2012, 03:55:49 PM »
I think I understand you  now.
We have seen where units that do not receive the correct voltage and current (i.e. Power) may not correctly operate including not powering off.  The power button is not a direct switch.  It sends a signal to the computer chip to start the shutdown sequence for the unit.  If something interrupts that or if something is not working right; than the unit will not shut off properly.
We have also seen where some cabling that has become unwittingly damaged and grounded to the boat has prevented units from powering off.
By the way; make sure that you are holding in the power button long enough for the unit to recognize that you want to power it off.  This takes a few seconds.
Offline andre
« Reply #7 on: November 06, 2012, 03:51:00 PM »
a sonic depth finder 12,6вт food a wire a food in norm, the button inclusion not correctly works.и the screen of the sonic depth finder blinks I (flicker) sent the sonic depth finder to the dealer in Latvia (нормарк) they will send the sonic depth finder to you on a guarantee
Offline andre
« Reply #8 on: November 09, 2012, 10:53:57 AM »
thanks for support  :'(
Last post May 03, 2010, 02:21:19 AM
Last post July 14, 2011, 04:30:42 PM
Last post January 20, 2012, 06:49:21 PM
by iliveinakeg
Last post May 01, 2012, 02:22:26 AM
by Wylezalek
Last post May 04, 2012, 04:19:54 AM
by Rüdiger
Last post June 09, 2012, 08:56:30 AM
by Wylezalek
Last post February 10, 2015, 03:11:54 AM
by peterv6i
Last post June 30, 2014, 01:49:55 PM
