Author Topic: 798 si temperture problem  (Read 4159 times)
Offline hgv
  • Unit(s): 798ci HD SI
  • Software: 6.x
« on: October 14, 2012, 10:24:34 PM »
The unit has been woking perfect when I noticed this past weekend the 798 was reading 100 degrees for the water temperature. The unit would report the correct temperature occasionally which was around 70 degrees. What shgould I check?
As i mentioned it has been working perfect until this last trip to the lake everything looks fine.
Re: 798 si temperture problem
« Reply #1 on: October 15, 2012, 01:06:27 PM »
hgv,
Try connecting your 798 unit to another Humminbird transducer that has the built-in temperature sensor (most of them do).  Usually the problem is the temperature sensor in the transducer going bad.
Offline hgv
  • Software: 6.x
« Reply #2 on: October 15, 2012, 01:13:34 PM »
Well that sucks, I have not even had it a year!
« Reply #3 on: October 15, 2012, 01:45:50 PM »
Sounds like it may be time for a warranty replacement on the transducer than.
Call the Humminbird Customer Resource folks and see about getting it replaced.
« Reply #4 on: October 15, 2012, 04:02:14 PM »
Yes indeed.  See about a swap or a replacement. These transducers are susceptable to dings and bumps and abuse..
Last post July 25, 2009, 02:24:11 PM
Last post August 29, 2012, 10:51:48 AM
Last post February 09, 2011, 02:04:08 PM
by terry0540
Last post May 12, 2011, 04:34:08 PM
Last post June 01, 2012, 12:16:49 PM
Last post March 27, 2012, 11:18:56 AM
Last post October 15, 2012, 04:28:12 PM
Last post October 08, 2012, 02:08:10 PM
