Author Topic: 570 DI portable with XNT 9 DI T  (Read 8866 times)
Offline icliao
« on: October 03, 2012, 03:17:20 AM »
I would like to buy a portable unit but I notice the 570 DI is rated for 250 ft (DI) and 596c HD DI is rated for 350 ft (DI.) I definitely need the extra 100 ft DI capability so which unit should I buy? Is it possible to buy 570DI and buy 596c unit's transducer to increase the DI depth scanning range? Is there any SI unit that can scan upto 350 ft in DI mode?
Re: 570 DI portable with XNT 9 DI T
« Reply #1 on: October 03, 2012, 10:54:16 AM »
The 570 DI and 596c HD DI use the same transducer.
The max DI depth specification for the 570 DI has not been changed yet but will be the same as the 596c HD DI unit (and all the other DI units once they get changed).  Through on-water testing it was confirmed that the DI sonar in these units will perform to 350 feet deep.  Not sure where this testing was done so your results may vary.  So the differences in the displays these units use is the only difference.
The 596c HD DI can be made portable as well by buying the PTC-U or PTC-U NB portable kits or by making your own.
No, the Si units cannot scan the Si sonar to that water depth (so the Di sonar will not work that deep either).
Last post November 01, 2010, 09:19:27 AM
by CHOOhonets
Last post November 16, 2010, 09:21:26 AM
Last post April 23, 2011, 03:43:07 AM
by Rüdiger
Last post February 05, 2013, 11:45:54 PM
by EZM
Last post March 11, 2014, 09:59:57 PM
by Stymie
Last post February 17, 2015, 09:40:48 AM
by bobbyb
Last post December 22, 2015, 03:05:40 PM
by Ken L
Last post January 20, 2016, 05:42:04 PM
by MadCatter
